error compiling...and Im up against the clock
- MMARK
Re: error compiling...and Im up against the clock
ADDED LIBRARIES...BUT NOTHING SHOWS UP ON DISPLAY EVEN EXAMPLES FROM "SD" ...THE SKETCH COMPLIES BUT NO IMAGE??? i HAVE TO BE MISSING A LIBRARY??
- adafruit_support_carter
Describe how you formatted the SD card and added the image files.
If you are missing a required library, the code will not compile. What additional libraries did you install?
- MMARK
I opened disk utility and erased it and left is as is...I took an image in photoshop and formatted to bmp. and checked pixel size ..Photoshop does have 24 bit option so I applied it ...I will attach what I have for libraries...but not the simple graphic test that worked yesterday and this morning isnt working...
- Screen Shot 2017-04-07 at 1.15.11 PM.jpg (342.15 KiB) Viewed 818 times
- Find a way to insure that you are formatting the SD card with FAT16 or FAT32.
- Use the image from the guide so you are using a known working image.
- MMARK
ok I will look for a way to make sure its fat24 or fat16
- MMARK
STILL LOOKING FOR WAY TO FORMAT TO FAT24..MAC JUST OFFERS MS-FAT OR EXFAT....
BUT TRIED MY GRAPHIC TEST AGAIN ..COMPLIED BUT NO IMAGE...COULD IT BE SOMETHING ELSE...i HAVE ALL THE LIBRARIES INCLUDED SD, SPI ???
If the SD card is not formatted with a supported file system, it will essentially be non-readable. If the image is not of a supported size and type, it will be non-displayable.
- MMARK
THAT MAKES SENSE...ANY WAY AROUND FORMATTING ON A MAC...??
- MMARK
Disk Utility on Mac wont let me partition my 16gb micro card ?? DO i need to get a new micro card
- MMARK
Just used the sd formatter and the serial monitor said initialization failed and gave me suggestions
- MMARK
I will try a 2g card could that make a difference??
- MMARK
So I get this error after formatting etc.
- Screen Shot 2017-04-09 at 11.43.51 AM.jpg (204.17 KiB) Viewed 719 times
- MMARK
THIS SHOWS MY CARD AND ITS SAYS FAT16..FORMATTED ON MAC'S TERMINAL..
- Screen Shot 2017-04-09 PM.jpg (246.72 KiB) Viewed 710 times
Running what sketch?So I get this error after formatting etc.
