Which Motor For Kinetic Sculptures Workshop?
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
lizzyB
Post by lizzyB »
Hello Adafruit!
Can anyone advise me on a simple and affordable (under $10?) motor that I can use without a controller? Movement can be very basic, anything that goes on/off.
I am teaching a two day workshop in kinetic sculptures and I'd like to incorporate a light motor to power something like a mobile (continuous motion sculpture). My students will not have coding experience and I am hoping to avoid using Arduino-- both for the increased cost and also because I think we'll get bogged down in tech. We will have circuit/soldering supplies and batteries.
Thank you for any suggestions!
Lizzy
Re: Which Motor For Kinetic Sculptures Workshop?
You might want start with a read through this guide: https://learn.adafruit.com/adafruit-mot ... -of-motors
A couple of very basic questions you will need to consider are: How massive are these sculptures and how fast do you want them to move?
Since you are avoiding any kind of control, you will need a motor that when connected to a power source will simply run at a reasonable speed and with reasonable torque to move your sculptures. That probably means some sort of gearmotor.
For small and relatively lightweight sculptures, these may work for you.
https://www.adafruit.com/product/2941
Pololu has a much wider range of gearmotors of various sizes and gear ratios: https://www.pololu.com/category/22/motors-and-gearboxes
lizzyB
Post by lizzyB »
Thank you! This is perfect. I will experiment :)
Return to “For Educators”
