barcode
barcode
by FutureEngineer on Sat Dec 16, 2017 5:04 am
Good morning
I need to interface the barcode reader linked below to Arduino.
I am using PS2 to breadboard connector also linked below.
https://www.adafruit.com/product/1202
https://www.adafruit.com/product/804
There can some issues that need clarifications:
Why there are two connectors used with the barcode reader (male and female)
Can you please refer to a startup tutorial with step by step guide on how to interface the barcode reader to Arduino.
Appreciate your early reply.
Thank you
FutureEngineer
Re: barcode
by FutureEngineer on Sat Dec 16, 2017 8:26 am
I connected the barcode reader as below.
The barcode terminals are listed below.
Brown is data
Green is VCC
Black is ground
Yellow is clock
I used this connection diagram
https://playground.arduino.cc/Component ... odeScanner
Attached is the connection.
Please reference an Arduino code for the scanner.
when I press on the button at the scanner, the flash light turns ON and OFF but there is no sound.
FutureEngineer
Re: barcode
by FutureEngineer on Sun Dec 17, 2017 12:39 am
Good morning.
Any help is appreciated.
FutureEngineer
Re: barcode
by FutureEngineer on Sun Dec 17, 2017 1:15 am
Dears,
I spent a lot of money on this barcode scanner, I actually purchased two of them.
And I need to make them work, please your technical support is urgently needed here.
Thanks.
FutureEngineer
Re: barcode
by franklin97355 on Sun Dec 17, 2017 1:44 am
When you respond to your own post it takes it off the list of topics without responses and sometimes that slows down a response. I'll see if there is an answer to your question since I don't know that product.
franklin97355
Re: barcode
by FutureEngineer on Sun Dec 17, 2017 2:55 am
Kindly check the connector image to check each colored wire is correctly identified.
These are from the male connector of the barcode scanner.
They are connected as below:
Brown wire (pin 1 in the male connector) is data and it's connected to pin 2 in Arduino (through a 2.2k resistor).
Black wire (pin 3 in the male connector) is connected to ground.
Yellow wire (pin 5 in the male connector) is clock and it's connected to pin 3 in Arduino (through a 2.2k resistor)
Green wire (pin 4 in the male connector) is connected to VCC
The white and the red (pin 2 and 6 respectively) are not connected
Kindly check image 2 that shows the connection to Arduino.
I am using three resistors of 1k, 1k and 220 to get the 2.2kohms resistor.
barcode1.pdf
(1.16 MiB) Downloaded 24 times
Last edited by FutureEngineer on Sun Dec 17, 2017 2:57 am, edited 1 time in total.
FutureEngineer
Re: barcode
Kindly check the code and the connection to Arduino mega attached.
Barcode Scanner
   This code reads the input from a ps/2 keyboard or keyboard-like
   device (e.g. a barcode scanner), translates the scan-codes into
   numbers (only numbers from 0 to 9 can be used at the moment)
   It is nowhere near a complete implementation of the ps/2 protocol,
   but it should give you a starting point.
   mys .// Benjamin Maus   ( benjamin.maus <at> allesblinkt.com )
   2007
int SCAN_ENTER = 0x5a; int SCAN_BREAK = 0xf0;
int breakActive = 0;
int clockPin = 3; // Clock is only output.
int dataPin = 2; // The data pin is bi-directional
            // But at the moment we are only interested in receiving
int ledPin = 13;  // When a SCAN_ENTER scancode is received the LED blink
int clockValue = 0; byte dataValue;
byte scanCodes[10] = {0x45,0x16,0x1e,0x26,0x25,0x2e,0x36,0x3d,0x3e,0x46}; char characters[10] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
int quantityCodes = 10;
char buffer[64] = {};   // This saves the characters (for now only numbers)
int bufferPos = 0;
int bufferLength = 64;
   pinMode(dataPin, INPUT);
   pinMode(clockPin, INPUT);
   pinMode(ledPin, OUTPUT);
   Serial.begin(9600);
   dataValue = dataRead();
   // If there is a break code, skip the next byte
   if (dataValue == SCAN_BREAK) {
      breakActive = 1;
   // Translate the scan codes to numbers
   // If there is a match, store it to the buffer
   for (int i = 0; i < quantityCodes; i++) {
      byte temp = scanCodes[i];
      if(temp == dataValue){
         if(!breakActive == 1){
            buffer[bufferPos] = characters[i];
            bufferPos++;
   //Serial.print('*'); // Output an asterix for every byte
   // Print the buffer if SCAN_ENTER is pressed.
   if(dataValue == SCAN_ENTER){
      Serial.print("\nbuffer: ");
      // Read the buffer
      int i=0;
      if (buffer[i] != 0) {
         while(buffer[i] != 0) {
            Serial.print( buffer[i] );
            buffer[i] = 0;
            i++;
      Serial.println(" [Enter]");
      bufferPos = 0;
      // Blink the LED
      digitalWrite(ledPin, HIGH);
      delay(300);
      digitalWrite(ledPin, LOW);
   // Reset the SCAN_BREAK state if the byte was a normal one
   if(dataValue != SCAN_BREAK){
      breakActive = 0;
   dataValue = 0;
int dataRead() {
   byte val = 0;
   // Skip start state and start bit
   while (digitalRead(clockPin));  // Wait for LOW.
   // clock is high when idle
   while (!digitalRead(clockPin)); // Wait for HIGH.
   for (int offset = 0; offset < 8; offset++) {
      val |= digitalRead(dataPin) << offset; // Add to byte
// Skipping parity and stop bits down here.
   return val;
barcode2.pdf
(950.44 KiB) Downloaded 22 times
FutureEngineer
Re: barcode
by FutureEngineer on Sun Dec 17, 2017 3:38 am
Now it's working. I was not careful of the distance between the reader and the barcode.
FutureEngineer
Re: barcode
by FutureEngineer on Sun Dec 17, 2017 8:20 am
Another technical question I have,
how can I activate the barcode reader using an external push button rather than the built-in of the reader ?
FutureEngineer
Re: barcode
by adafruit2 on Sun Dec 17, 2017 1:33 pm
you'd have to carefully solder two wires to the built-in switch, then you can attach your own button!
adafruit2
Site Admin
Re: barcode
by FutureEngineer on Mon Dec 18, 2017 1:25 am
Can I activate it using a command from Arduino ?
FutureEngineer
Re: barcode
by FutureEngineer on Mon Dec 18, 2017 1:56 am
I managed to modify the code to compare the scanned code with the saved ones.
When I run the code, it only identifies the first barcode correctly and then nothing appear at the serial monitor, it's like the serial monitor freezes.
Despite that the buzzer make the sound of detecting the barcode, any idea why I have this problem ?
int clockPin = 3;
int dataPin = 2;
int clockValue = 0;
byte dataValue;
char check[10]={'0','0','0','0','0','0','0','0','0','0'};
int bufferPos = 0;
char tag1[5] = {'6','2','9','1','0'}; //masafi
char tag2[5] = {'6','2','9','1','1'}; //alain
char tag3[5] = {'6','2','9','7','0'}; //maiDubi
char tag4[5] = {'5','4','4','9','0'}; ////cocacola
char tag5[5] = {'0','1','2','0','0'}; ////7up
char tag7[5] = {'6','2','8','1','0'}; ////Al Rabie
char tag8[5] = {'4','7','9','2','0'}; ////Coconut water
int count=0;
   Serial.begin(115200);
      breakActive = 1;
            bufferPos++;
      // Read the buffer
      int i=0;
            Serial.print( buffer[i]);
                                 check[i]=buffer[i];
             buffer[i] = 0;
            i++;
                 if (check[0] ==tag1[0]  && check[1] == tag1[1] && check[2] ==tag1[2]  && check[3] ==tag1[3] && check[4] ==tag1[4]  ) {Serial.println("\tMasafi"); count=count+1; Serial.print("count=");Serial.println(count);}
                 if (check[0] ==tag2[0]  && check[1] == tag2[1] && check[2] ==tag2[2]  && check[3] ==tag2[3] && check[4] ==tag2[4] ) {Serial.println("\tAlain");}
                 if (check[0] ==tag3[0]  && check[1] == tag3[1] && check[2] ==tag3[2]  && check[3] ==tag3[3] && check[4] ==tag3[4]){Serial.println("\tMai Dubai");}
                 if (check[0] ==tag4[0]  && check[1] == tag4[1] && check[2] ==tag4[2]  && check[3] ==tag4[3] && check[4] ==tag4[4] ) {Serial.println("\tCocacola");}
                 if (check[0] ==tag5[0]  && check[1] == tag5[1] && check[2] ==tag5[2]  && check[3] ==tag5[3] && check[4] ==tag5[4]){Serial.println("\t7UP");}
                 if (check[0] ==tag7[0]  && check[1] == tag7[1] && check[2] ==tag7[2]  && check[3] ==tag7[3] && check[4] ==tag7[4]){Serial.println("\tAl Rabie");}
                 if (check[0] ==tag8[0]  && check[1] == tag8[1] && check[2] ==tag8[2]  && check[3] ==tag8[3] && check[4] ==tag8[4]){Serial.println("\tCocunut Water");}
      bufferPos = 0;
      // Blink the LED
      delay(300);
      breakActive = 0;
   dataValue = 0;
int dataRead() {
   byte val = 0;
   return val;
run.pdf
(237.06 KiB) Downloaded 15 times
FutureEngineer
Re: barcode
by FutureEngineer on Mon Dec 18, 2017 7:08 am
Why sometimes the scanner sound the beep but I don't get any thing at the serial monitor?
Please I need the reply.
FutureEngineer
Re: barcode
by adafruit2 on Mon Dec 18, 2017 1:13 pm
sounds like something with your code crashed, go back to the working code you had before!
adafruit2
Site Admin
Re: barcode
by FutureEngineer on Mon Dec 18, 2017 3:30 pm
Now it's detecting correctly, but I need to do a simple count, but the program is not counting.
I am not sure why?? I spent three hours trying to fix the count problem without any success.
//////////////// serial LCD
int x =1;
#include <SoftwareSerial.h>
SoftwareSerial mySerial(15,14);   /////first one doesnt matter
int clockPin = 3;
int dataPin = 2;
int clockValue = 0;
byte dataValue;
int bufferPos = 0;
int count=0;
        mySerial.begin(9600);
        while(!Serial){ ; }
        while(!mySerial){ ; }
        delay(500);
       mySerial.write(254); mySerial.write(128);
       mySerial.write("                "); // clear display;
       mySerial.write(254); // move cursor to beginning of first line
       //mySerial.write("welcome");
        Serial.print(dataValue);
      breakActive = 1;
            bufferPos++;
                //count=count+1; Serial.print("count=");Serial.println(char(count));delay(200);
      // Read the buffer
      int i=0;
                                 check[i]=buffer[i];
             buffer[i] = 0;
            i++;
                    {Serial.println("\tMasafi"); mySerial.write("Masafi");count=count+1; Serial.print("count=");Serial.println(count);delay(200);}
                    {Serial.println("\tAlain");mySerial.write("Alain");count=count+1; Serial.print("count=");Serial.println(count);delay(200); }
                    {Serial.println("\tMai Dubai");mySerial.write("Mai Dubai");count=count+1; Serial.print("count=");Serial.println(count);}
                    {Serial.println("\tCocacola");mySerial.write("Cocacola");count=count+1; Serial.print("count=");Serial.println(count);}
                    {Serial.println("\t7UP");mySerial.write("7UP");count=count+1; Serial.print("count=");Serial.println(count);}
                    {Serial.println("\tAl Rabie");mySerial.write("Al Rabie");count=count+1;Serial.print("count=");Serial.println(count);delay(200); }
                    {Serial.println("\tCocunut Water");mySerial.write("Cocunut Water");count=count+1;Serial.write("count="); Serial.write(count);delay(200); }
      Serial.print(" [count=]");
                count = count+1;
                mySerial.write(count);
                for (int i=0; i <= 10; i++){ Serial.print(check[i]);  delay(10); }
      bufferPos = 0;
      // Blink the LED
      delay(300);
      breakActive = 0;
   dataValue = 0;
int dataRead() {
   byte val = 0;
   return val;
FutureEngineer
