RGB LCD Shield 2 pins question?
by 1885 on Mon Jan 01, 2018 11:49 am
I just assembled the RGB LCD with 2 pins. https://learn.adafruit.com/assets/1390
Molto epico
I just want to confirm the specs
The RGB LCD uses I2C pins on Analog 4 and Analog 5.
I found this https://www.arduino.cc/en/Reference/Wire as documentation for I2C.
I've never used I2C so I need to do some reading.
The Question?
So this means I can use A0, A1, A2, A3 along with D2 to D13 along with RX/TX
and I'll need a voltage source is if I want to power something like a
Wire nRF24L01+ to Arduino UNO
GND <–> GND
VCC <–> Arduino 3.3V
CE <–> Arduino pin 9
CSN <–> Arduino pin 10
SCK <–> Arduino pin 13
MOSI <–> Arduino pin 11
MISO <–> Arduino pin 12
Thanks Adafruit!
1885
Re: RGB LCD Shield 2 pins question?
by adafruit_support_bill on Mon Jan 01, 2018 12:24 pm
Connecting to an UNO, the shield requires GND, 5v, SDA (A4) and SCL (A5).
Not sure about the voltage requirements of your nRF24L01+ module. If it is a 3.3v device, you may need some voltage level shifting between the 5v UNO and the module. I'd check with the module manufacturer to be sure.
by 1885 on Mon Jan 01, 2018 12:56 pm
adafruit_support_bill wrote:Connecting to an UNO, the shield requires GND, 5v, SDA (A4) and SCL (A5).
Thanks! I'll get 3.3V from 5V with a voltage drop. Everything else should work fine. Thanks!
1885
