TMP36
TMP36
by nhodgson5 on Tue Jan 02, 2018 3:19 pm
Hi, I ordered 30 TMP36 sensors to use in my classes and the majority of them seem to not be calibrated. Going by the tutorial on the adafruit website, the voltage being read from the sensor should be about .75 V at room temp, but we're getting about .55-.65. Any thoughts? Thanks
nhodgson5
Re: TMP36
by franklin97355 on Tue Jan 02, 2018 9:18 pm
How are you testing these and what readings are you getting at what temperature? At 20 C ( 68 F )you should get 0.70
franklin97355
Re: TMP36
by nhodgson5 on Wed Jan 03, 2018 10:27 am
With a voltmeter and through the Arduino's serial monitor--getting the same readings. In a room temp classroom.
nhodgson5
Re: TMP36
by franklin97355 on Wed Jan 03, 2018 4:43 pm
What is the temp in the classroom and what are you powering the TMP36 with? What is the meter giving you at that room temperature?
franklin97355
