MPS2 907A 137
And that's for both of them.
Drawdio - need some eyes
- adafruit2
Re: Drawdio - need some eyes
thats right. so...I dont know what the issue is. sorry :/ we could replace the drawdio or refund it :) at some point its something with your setup and we can't figure it out. let us know what you wanna do!
- MarthaV
ok; Good news, sortof!
on the pcb board where I soldered the speaker directly to the board, with much wiggling I'm getting sound!!!
on the pcb board where the speaker is soldered with the wire, no joy, silence.
- MarthaV
Here's what I'd like to do.
I'd like to send you the one I assembled without luck and then, you can have a look-see and send me a replacement if it's truly the kit versus operator error on my part.
Is that ok?
Is that ok?
- adafruit2
ok sounds like a soldering issue, we don't do debugging by mail, so maybe check your speaker wiring/soldering, see if you can spot the problem there!
- MarthaV
I'm back. I've made another try. Oh gosh, I hope you can help. On the last two from last month I was only able to get some sound on one of them but when I used the copper tape and attached it to a pencil, nothing happened.
Today I did a new build and when I tested prior to soldering I got some sound. But now that the pencil is attached with copper wire, nothing.
When I squeeze the bottom of the pencil with the copper wire, I hear noise but if I write with the pencil, nothing happens, even when I'm holding on tight to that copper wire.
I'm very eager to get this to work and the last drawdio pack I purchased was a five pack. I only have one left to try and build sooooo.
If you guys can help me that would be terrific.
- IMG_0010.JPG (59.9 KiB) Viewed 664 times
- adafruit2
sounds like the board works, there's just a disconnection somewhere. try touching the board/copper tape pencil until you find where the connectivity was 'lost'! :)
- MarthaV
you guys are great! such a prompt response!
OK. when I touch the copper tape near the end of the pencil that has the thumbtack in it. All is good, noise and whistles and bells!
When I touch the copper tape at the bottom, it's inconsistent. Sometimes whistles but sometimes nothing. And always nothing when I try to write with it.
Now, I did solder the tape to the pcb board on both ends.
Curiouser and curiouser.
- adafruit2
maybe replace that bottom tape? it could be cracked
- MarthaV
Well, when I hold the top of the pencil I can play out music and rhythms on the bottom part of the copper and the copper doesn't look cracked. Should I go ahead and try new copper though? Also, I soldered the copper tape on top and bottom is there anyway that could have a negative effect on the finished product?
- adafruit2
so its the connection THROUGH the pencil that isnt working?
- MarthaV
I think so. It is soundless when I write but makes a sound when I touch copper at the top and copper at the bottom, or just copper at the top.
- marshaj847
You might need to check the polarity of the capacitor, in one of the boards it may be backwards
- MarthaV
k; I'll check that; thanks.
- MarthaV
In my pursuit to finally get this going, I bought two pre-built kits; Hoping to at least get these running.
When I press on both sides of the PCB board, sound comes out,
When I write with the pencil, nothing, radio silence.
What am I doing wrong?
- IMG_0023 (1).JPG (23.48 KiB) Viewed 528 times
