I want to put together the thermal camera (AMG8833). The sensor only supports I2C. I want to use this in a small demo for CosPlay.
What is the smallest Arduino there is with I2C?
I thought it would be a Pro Trinket but I didn't see I2C in the specs. Anyone got another idea?
Thank you!
What is the smallest Arduino with I2C??
- Franklin97355
Re: What is the smallest Arduino with I2C??
Take a look at this. A4 and A5 are the i2c pins.
- tkinsman
Thanks Franklin.
Okay. So the over-view specs do not include all the details I need. And, when looking for the I2C connections I should search for "SDA" which is that acronym for one of the two IC2 pins.
Using this trick, it looks like the Trinket (smaller then a Pro Trinket) also has I2C.
Now I am on to trying to run a thermal camera to TFT on it.
Thank you!
Thank you!
- adafruit_support_bill
The i2c bus uses 2 pins: SDA for the data signal and SCL for the clock signal.And, when looking for the I2C connections I should search for "SDA" which is that acronym for one of the two IC2 pins.
