BRAND NEW RP 3+ - WONT CONNECT TO WIFI
- JerryBoi831
This is a brand new board, just placed in case and OctoPrint image flashed onto sd, network has been configured but cannot find it AT ALL on the network map or even via the ip browser on my local network. Is not connected. Power to board seems fine so maybe wifi is dead. Need help asap
- Franklin97355
Re: BRAND NEW RP 3+ - WONT CONNECT TO WIFI
Did you use the latest image from the Pi foundation? I'd recommend trying Raspbian.
- JerryBoi831
No i have not, just the octopi image, ill download raspbian now and try that
- JerryBoi831
Ok, so i installed it, its booted and all but only Ethernet connection works, no wifi so its definitely a bad board and need a replacement
- adafruit2
you need to do Stuff to turn on WiFi, by selecting the country, its new to the pi 3 B+
run sudo raspi-config i think its in there!
- JerryBoi831
Already did all that and set to usa English and still, says no wireless interface found. I need a replacement. Already flashed image 3 separate times to diff sd cards, changed region, etc and still same error
- adafruit2
weird, ok email support@adafruit and we'll replace it.
- JerryBoi831
ok thank you, email has been sent
