We cannot get the drum glove to work. We followed the instructions for the build and finally got the Adafruit boards installed with a link someone posted on the forum to add board URL in preferences. Now the program won't work with the Flora. Please help. We installed NanoStudio, but do not know how to make it connect so the glove fingers can operate as the keyboard presses.
Midi Drum Glove Project
- adafruit_support_carter
Re: Midi Drum Glove Project
Back up a little and go through the basic FLORA intro guide:
https://learn.adafruit.com/getting-star ... a/overview
Make sure you can get the blink example to load and run first. If you still have trouble with that, report back.
- Franklin97355
What errors do you get and what does not work?Now the program won't work with the Flora.
- gambinos
We've already gotten the blink to work. We also made a lie detector last year and a GPS jacket (it was much easier on a Mac, but now we are using these at school with Windows!!).
The problem we currently have with the midi drum glove program is that the word 'keyboard' in the program errors out and is not recognized. How can we connect to the music program? Any help greatly appreciated.
Try putting this line at the top of your sketch:
#include <Keyboard.h>
- Franklin97355
Post the code you are trying to compile and we will take a look.
- gambinos
I tried the include keyboard line, but that is errors out too.
Piezo Keyboard glove
products from Adafruit!
Written by Limor Fried & Becky Stern for Adafruit Industries.
BSD license, all text above must be included in any redistribution
const int indexFinger = A9; // the piezo is connected to analog pin 9 (aka D9)
const int middleFinger = A7; // the piezo is connected to analog pin 7 (aka D6)
const int thumb = A10; // the piezo is connected to analog pin 10 (aka D10)
const int pinkyFinger = A11; // the piezo is connected to analog pin 11 (aka D12)
const int pins[] = {thumb, indexFinger, middleFinger, pinkyFinger};
char Keys[] = {'z','x','c','v'};
boolean currentPressed[] = {false, false, false, false};
const int threshold = 40; // threshold value to decide when the detected sound is a knock or not
void setup()
//while (!Serial)
Serial.begin(115200);
Serial.println("start");
Keyboard.begin();
void loop()
for (int i=0;i<4;i++) {
delay(1);
long total1 = 0;
long start = millis();
long total = analogRead(pins[i]);
// check if we are sensing that a finger is touching
// and that it wasnt already pressed
if ((total > threshold) && (! currentPressed[i])) {
Serial.print("Key pressed #"); Serial.print(i);
Serial.print(" ("); Serial.print(Keys[i]); Serial.println(")");
currentPressed[i] = true;
Keyboard.press(Keys[i]);
else if ((total <= threshold) && (currentPressed[i])) {
// key was released (no touch, and it was pressed before)
Serial.print("Key released #"); Serial.print(i);
currentPressed[i] = false;
Keyboard.release(Keys[i]);
delay(5);
Last edited by adafruit_support_carter on Mon May 07, 2018 11:19 am, edited 1 time in total.
Reason: added [code] tags
- gambinos
Error message:
drumglove.ino:13:22: fatal error: Keyboard.h: No such file or directory
compilation terminated.
Error compiling.
Using the Flora Mainboard Version B
Error compiling.
What version of the Arduino IDE are you using? Check and make sure the Keyboard library is installed:
Sketch -> Include Library -> Manage Libraries...
type "keyboard" in the "Filter your search..." window and make sure the library shows up in the list.
- gambinos
Thank you, I installed these libraries and now the program says it uploaded, but it's still not making any sound. I have NanoStudio open - how do I make it communicate with Flora?
- gambinos
I also put these includes at the top of the program:
#include <HID.h>
#include <HID.h>
If you open the serial monitor in the Arduino IDE, do you see anything being printed there when you try to use the glove?
- gambinos
No, nothing is printing in the serial monitor, but I do see on COM13 (Adafruit Flora)
Hmm. If you're running the first demo code from here (with the needed #includes added):
https://learn.adafruit.com/midi-drum-glove/code
you should see some output printed to the serial console when you try to use the glove. Something like:
Try lowering the value for threshold on this line:
and see if you can get the glove to respond.
Key pressed #0 (z)
Key released #0 (z)
- gambinos
I went down to 10, still no response. I could not get the Flora board choice from Teensyduino to show up. Could this have something to do with it? I only see Teensy 3.6, 3.5, 3.2/3.1/ 3.0 LC, 2.0 and ++2.0 We chose just the regular Flora.
