how to turn off a boost board at 3.2 volts
- jojo4155
using a solar charger V2, 3.7 volt lith-ion battery connected to battery connector and boost board connected to load connection. I would like the following to occur. when the charger board is unable to supply the current or during the night when it is off. The battery is switched in (does the charger board switch to battery when off?. Secondly how to turn off the boost board at 3.2 volts, at present it indicates but still draws power from the battery. the board needs to do this function without any outside assistance.
