I am trying to test my NeoPixel Matrix ( Flexible, 8x8). I am using demo code from the Neopixel library but I keep getting this error,
Arduino: 1.8.5 (Mac OS X), Board: "Adafruit Gemma M0"
Sketch uses 20960 bytes (7%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port /dev/cu.usbmodem145201
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.RichardsAirPods-Wireles, /dev/cu.SOC, /dev/cu.usbmodem145201, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.RichardsAirPods-Wireles, /dev/tty.SOC, /dev/tty.usbmodem145201, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.RichardsAirPods-Wireles, /dev/cu.SOC, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.RichardsAirPods-Wireles, /dev/tty.SOC, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.RichardsAirPods-Wireles, /dev/cu.SOC, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.RichardsAirPods-Wireles, /dev/tty.SOC, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.RichardsAirPods-Wireles, /dev/cu.SOC, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.RichardsAirPods-Wireles, /dev/tty.SOC, } => {}
PORTS {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.RichardsAirPods-Wireles, /dev/cu.SOC, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.RichardsAirPods-Wireles, /dev/tty.SOC, } / {/dev/cu.Bluetooth-Incoming-Port, /dev/cu.MALS, /dev/cu.RichardsAirPods-Wireles, /dev/cu.SOC, /dev/cu.usbmodem145201, /dev/tty.Bluetooth-Incoming-Port, /dev/tty.MALS, /dev/tty.RichardsAirPods-Wireles, /dev/tty.SOC, /dev/tty.usbmodem145201, } => {/dev/cu.usbmodem145201, /dev/tty.usbmodem145201, }
Found upload port: /dev/cu.usbmodem145201
{runtime.tools.bossac-1.7.0.path}/bossac -i -d --port=cu.usbmodem145201 -U true -i -e -w -v /var/folders/2_/d082r70d7kvbz2l1ld_wmz040000gn/T/arduino_build_879941/MatrixGFXDemo.ino.bin -R
java.io.IOException: Cannot run program "{runtime.tools.bossac-1.7.0.path}/bossac": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:207)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:78)
at processing.app.SketchController.upload(SketchController.java:713)
at processing.app.SketchController.exportApplet(SketchController.java:686)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2168)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:247)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 10 more
An error occurred while uploading the sketch
Any help would be great!!!
Richard
Arduino IDE Gemma M0 Neopixel Matrix
- ipadeflteacher
Re: Arduino IDE Gemma M0 Neopixel Matrix
I deleted Arduino and all the files. Before reinstalling everything I tried CodeBender.cc. I was able to upload the code successfully but only one light worked on the Flora Neopixel and one on the NeoPixel ring. Then I discovered in the code comments // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2) I have a v1.
Where would be the best place for me to get help changing the code to fit v1?
Thanks again for all the help!
Richard
Richard
