hello
product: FTDI SERIAL TTL-232 USB CABLE
link: https://www.adafruit.com/product/70
i bought from idealink distributor in Kuwait since 3 days
i tried with 3.3V signal and worked well
question is: does it work with 5v too?
as there is other cheaper models with same chip support 3.3V and 5V Operation using manual Jumper.
for exaxmple am trying to use it with Huawei SmartAX MA5672 BBU
puty config:
here is voltmeter check:
that check from first & second PIN from left to right
can (FTDI SERIAL TTL-232 USB CABLE) operate with 5v TTL sign
- alaa2003
Re: can (FTDI SERIAL TTL-232 USB CABLE) operate with 5v TTL
Yes. The signal pins are 5v compliant. It will work with either 3.3v or 5v signals.i tried with 3.3V signal and worked well
