SGP30 for Flora
SGP30 for Flora
by jahrndt on Tue Apr 02, 2019 11:51 pm
I am currently working on a workshop to integrate an air quality sensor into a wearable for my students. I am having no luck integrating the sgp30 into my flora project. The serial monitor doesn't seem to be picking anything up. Any Suggestions?
jahrndt
Re: SGP30 for Flora
by franklin97355 on Wed Apr 03, 2019 1:09 am
Post your code and show us how you have things connected so we can help.
franklin97355
Re: SGP30 for Flora
by jahrndt on Tue Apr 09, 2019 11:56 am
Here is my Code it is just the example code for the SGP30 sensor. I have hooked up the flora exactly like the diagram.
#include <Wire.h>
#include "Adafruit_SGP30.h"
Adafruit_SGP30 sgp;
/* return absolute humidity [mg/m^3] with approximation formula
* @param temperature [°C]
* @param humidity [%RH]
uint32_t getAbsoluteHumidity(float temperature, float humidity) {
    // approximation formula from Sensirion SGP30 Driver Integration chapter 3.15
    const float absoluteHumidity = 216.7f * ((humidity / 100.0f) * 6.112f * exp((17.62f * temperature) / (243.12f + temperature)) / (273.15f + temperature)); // [g/m^3]
    const uint32_t absoluteHumidityScaled = static_cast<uint32_t>(1000.0f * absoluteHumidity); // [mg/m^3]
    return absoluteHumidityScaled;
  Serial.begin(9600);
  Serial.println("SGP30 test");
  if (! sgp.begin()){
    Serial.println("Sensor not found :(");
    while (1);
  Serial.print("Found SGP30 serial #");
  Serial.print(sgp.serialnumber[0], HEX);
  Serial.print(sgp.serialnumber[1], HEX);
  Serial.println(sgp.serialnumber[2], HEX);
  // If you have a baseline measurement from before you can assign it to start, to 'self-calibrate'
  //sgp.setIAQBaseline(0x8E68, 0x8F41);  // Will vary for each sensor!
int counter = 0;
  // If you have a temperature / humidity sensor, you can set the absolute humidity to enable the humditiy compensation for the air quality signals
  //float temperature = 22.1; // [°C]
  //float humidity = 45.2; // [%RH]
  //sgp.setHumidity(getAbsoluteHumidity(temperature, humidity));
  if (! sgp.IAQmeasure()) {
    Serial.println("Measurement failed");
    return;
  Serial.print("TVOC "); Serial.print(sgp.TVOC); Serial.print(" ppb\t");
  Serial.print("eCO2 "); Serial.print(sgp.eCO2); Serial.println(" ppm");
  delay(1000);
  counter++;
  if (counter == 30) {
    counter = 0;
    uint16_t TVOC_base, eCO2_base;
    if (! sgp.getIAQBaseline(&eCO2_base, &TVOC_base)) {
      Serial.println("Failed to get baseline readings");
      return;
    Serial.print("****Baseline values: eCO2: 0x"); Serial.print(eCO2_base, HEX);
    Serial.print(" & TVOC: 0x"); Serial.println(TVOC_base, HEX);
jahrndt
Re: SGP30 for Flora
by jahrndt on Mon May 27, 2019 7:49 pm
I am trying to create a wearable C02 sensor with the Flora and the SGP30 sensor for a series of workshops. Any suggestions? right now if I hook up them both at the same time the SGP30 stops sensing and shuts down. Any help would be appreciated.
Screen Shot 2019-05-27 at 7.42.30 PM.png (347.28 KiB) Viewed 917 times
jahrndt
