How to make Music Maker Louder
by weibelgl on Tue May 07, 2019 12:24 pm
Hello - I am using Adafruit "Music Maker" MP3 Shield for Arduino w/3W Stereo Amp with 8 ohm speakers.
My students need to have it louder - any suggestions?
weibelgl
Re: How to make Music Maker Louder
by adafruit_support_bill on Tue May 07, 2019 1:05 pm
Are you using bare speakers, or are they in an enclosure? Without an enclosure or baffle, the sound from the back-side of the speaker will partially cancel out the sound from the front. A simple baffle made from a board with a speaker-sized hole in it will be an improvement over a bare speaker.
by weibelgl on Tue May 07, 2019 1:15 pm
adafruit_support_bill wrote:Are you using bare speakers, or are they in an enclosure? Without an enclosure or baffle, the sound from the back-side of the speaker will partially cancel out the sound from the front. A simple baffle made from a board with a speaker-sized hole in it will be an improvement over a bare speaker.
Just the bare speaker - will try enclosing.
Let you know what they think.
weibelgl
by tkinsman on Tue Jun 18, 2019 10:01 am
I have a similar issue, but an enclose will not give enough volume.
Is there a recommended amplifier for music which can increase the volume?
tkinsman
by adafruit_support_bill on Tue Jun 18, 2019 10:19 am
There are 3 primary parts to the equation:
* The speaker(s) (including the enclosure)
* The amplifier
* The source signal
The amplifier will have a power rating in watts. It will also be rated for a certain range of speaker impedance (typically in the 4-ohm to 16 ohm range). To get full rated power to the speakers, select speakers rated for the amplifiers lowest impedance rating and a power rating equal or higher than the amp.
So if the amp is rated for 20 Watts into 4 ohms, you need 4 ohm speakers rated for at least 20 Watts.
But if your source signal is too weak, you may need to add a pre-amp to drive the rest of the system to its full potential.
by tkinsman on Sat Jun 29, 2019 12:18 am
Thank you.
tkinsman
