📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Adafruit cricket doesn’t work
by ToniEast on Thu May 09, 2019 10:27 pm
I ordered cricket board last month for my School project but it doesn’t work. I I have tried my classmates board it works good so I think my cricket doesn’t work
ToniEast
Re: Adafruit cricket doesn’t work
by ToniEast on Thu May 09, 2019 10:28 pm
Another picture
ToniEast
by franklin97355 on Thu May 09, 2019 11:10 pm
Just what part "doesn't work"? Can you tell us what you are trying and what is happening?
franklin97355
by ToniEast on Thu May 09, 2019 11:22 pm
It’s the motor part, I’m trying to contact my buggy’s motor but it doesn’t work
ToniEast
by franklin97355 on Fri May 10, 2019 2:29 am
What motor are you using and what are you powering it with?
franklin97355
by ToniEast on Fri May 10, 2019 7:02 am
The car buggy wheel motor and I use 4 (1.5) batteries
ToniEast
by ToniEast on Fri May 10, 2019 7:07 am
Buggy cars’s wheel and I powered it using 4 (1.5v) batteries
ToniEast
by ToniEast on Fri May 10, 2019 7:10 am
BONATECH Arduino 2 Wheels Smart Car Chassis Tracking Obstacle Avoidance Car Robot Chassis with Encoder Speed Detailed Tutorial https://www.amazon.com/dp/B07DMCWRJ1/re ... 1Cb99X8SNN
ToniEast
by danhalbert on Sun May 12, 2019 9:45 pm
4 1.5v alkaline batteries is too high a voltage. The Crickit has an electronic fuse that shuts it down if the voltage goes above 5.5V.
See this page for a discussion of powering the Crickit: https://learn.adafruit.com/adafruit-cri ... ng-crickit
In particular, for AA battery packs, use a 3-battery pack if you're using 1.5V alkalines (3*1.v = 4.5V). Only use a 4-battery pack if you're using NiMH, which are only 1.2V.
https://learn.adafruit.com/adafruit-cri ... -packs-4-7
Quoting also from that page:
The Cricket has two LEDs to let you know how the power supply is doing. If you see the green LED next to the smiley face, you're good to go. If you see the red LED next to the warning triangle, the voltage is too high, too low or too much current is being drawn.
danhalbert
by ToniEast on Wed May 22, 2019 9:36 pm
Boss if you focus in my picture that I have sent the light was green which mean the power is good
Also I ordered 1.2 batteries and also it does not work
Don’t talk. Let us cut to the chase are you going to replace or not
ToniEast
by danhalbert on Wed May 22, 2019 11:21 pm
"Please be positive and constructive with your questions and comments."
Here's a zoomed-in crop of one of your pictures, with the fuse LED's showing. The triangle ("power trouble") red LED is illuminated, which is why I suspected a power issue. The smiley face green LED is off.
The Crickit processor and the micro:bit are not affected by the fuse, so the micro:bit will work and you'll see LED's at the bottom of the board working, but the motor control part of the board will not be working.
Once a power-pack of 4 1.5V alkaline batteries gets run down somewhat, and the voltages drop, its total voltage may start to be low enough to work.
Please try your friend's setup with the identical battery pack, and swap micro:bits too if necessary to check your board and theirs. See what the fuse LED's are saying.
danhalbert
