📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Error conexion
Error conexion
by Justinnnnnnnnnnnnnnnnnnn on Tue May 28, 2019 8:01 am
Good morning, I have problems with the connection, I am using an adafruit code to connect to the Adafruit IO, but there is no way.
I really do not know what is happening;
- If the fault is in the Wi-Fi connection (I have tried it in two different Wi-Fi networks).
- Or if you are in connection with my Adafruit IO account.
- Or if the problem is in the microcontroller, I have also tested it with two different microcontrollers.
Add that I use the IDE Arduino 1.8.5 and I have the Adafruit IO library Arduino by Adafruit version 2.0.6; Adafruit MQTT Library version 1.0.3 and the Adafruit PN532
Someone could help me??
I attach the script.
Thank you
#include <Arduino.h>
#include "adafruit.h"//permite al programa de acceder que estan en la pestaña Adafruit.h, ahora podemos utilizar las funciones de otra pestaña
#define SENSOR D8
    pinMode(SENSOR, INPUT);
    pinMode(LED_BUILTIN, OUTPUT);
    Serial.begin(9600);
    //hay que llamar a la funcion despues de serial
    connectToAdafruitIO();
    Serial.println("Connexion activa");
    int movimiento = digitalRead(SENSOR);
    if (movimiento == LOW) Serial.println("Detectando");
    else Serial.println("No detectando");
    sendToAdafruitIO(movimiento);
    delay(2500);
sketch_may27a.ino
(628 Bytes) Downloaded 61 times
Reason: Added code inline for easier reading.
Re: Error conexion
by adafruit_support_carter on Tue May 28, 2019 1:18 pm
What microcontroller(s) are you using?
