Hello, I'm developing an assistive technology design project for first-year engineering students. I'm using Mu1.0.2 with CircuitPython 4.0.1 and CircuitPlayground Express with samd21g18 and adafruit-circuitpython-bundle-4.x-mpy-20190611. A key component of the project will be using accelerometer output to control the mouse cursor. In working through a sample implementation of the solution, I'm running into an error coming out of the hid library (I think). Input into mouse.move works fine when moving to the right or down. E.g.,
mouse.move(8, 0)
will move the cursor 8 to the right.
mouse.move(0, 8)
will move 8 down.
But any attempt to move to the left or up throws an error. E.g.,
mouse.move(-8, 0)
gives:
File "code.py", line 16, in <module>
File "adafruit_hid/mouse.py", line 147, in move
OverflowError: value must fit in 1 byte(s)
The problem is with negative numbers being input into mouse.move, but that seems to be the intended usage as given by the examples at https://circuitpython.readthedocs.io/pr ... mouse.html
Such as:
# Move 100 to the left. Do not move up and down. Do not roll the scroll wheel.
m.move(-100, 0, 0)
# Same, with keyword arguments.
m.move(x=-100)
# Move diagonally to the upper right.
m.move(50, 20)
# Same.
m.move(x=50, y=-20)
Thanks for any guidance!
hid.mouse overflowerror
