using multiple INA219 in a circuit
by criton07 on Wed Jul 17, 2019 11:05 am
hi there, I'am a newbie to arduino and circuits. I am using 3 ina219 in a circuit to measure current and voltage. i have gone through the adafruit ina219 datasheet.
My circuit consists of 3 mosfets which acts as electronic switches and is connected to 3 leds the each of the leds are further connected to ina219s respectively.the switches are turned on serially if i turn on mosfet 1(switch 1) all the ina219 gives out same values. please help me out..... the code used is given below. thanks in advance...
#include<Wire.h>
#include<Adafruit_INA219.h>
Adafruit_INA219 ina219_A;
Adafruit_INA219 ina219_B(0x41);
Adafruit_INA219 ina219_C(0x44);
int switch_1 = 6; //switch pins
int switch_2 = 7; //switch pins
int switch_3 = 5; //switch pins
void setup()
 uint32_t currentFrequency;
 Serial.begin(9600);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
ina219_A.begin();
ina219_B.begin();
ina219_C.begin();
 void loop(){
 // put your main code here, to run repeatedly:
 float shuntvoltage_1 = 0;// current voltage monitor 1
  float busvoltage_1 = 0;
  float current_mA_1 = 0;
  float loadvoltage_1 = 0;
  float power_mW_1 = 0;
  shuntvoltage_1 = ina219_A.getShuntVoltage_mV();
  busvoltage_1 = ina219_A.getBusVoltage_V();
  current_mA_1 = ina219_A.getCurrent_mA();
  power_mW_1 = ina219_A.getPower_mW();
  loadvoltage_1 = busvoltage_1 + (shuntvoltage_1 / 1000);
  Serial.print("Bus Voltage1:   "); Serial.print(busvoltage_1); Serial.println(" V");
  Serial.print("Shunt Voltage1: "); Serial.print(shuntvoltage_1); Serial.println(" mV");
  Serial.print("Load Voltage1:  "); Serial.print(loadvoltage_1); Serial.println(" V");
  Serial.print("Current1:       "); Serial.print(current_mA_1); Serial.println(" mA");
  Serial.print("Power1:         "); Serial.print(power_mW_1); Serial.println(" mW");
  Serial.println("");
 float shuntvoltage_2 = 0;// current voltage monitor 1
  float busvoltage_2 = 0;
  float current_mA_2 = 0;
  float loadvoltage_2 = 0;
  float power_mW_2 = 0;
  shuntvoltage_2 = ina219_B.getShuntVoltage_mV();
  busvoltage_2 = ina219_B.getBusVoltage_V();
  current_mA_2 = ina219_B.getCurrent_mA();
  power_mW_2 = ina219_B.getPower_mW();
  loadvoltage_2 = busvoltage_2 + (shuntvoltage_2 / 1000);
  Serial.print("Bus Voltage2:   "); Serial.print(busvoltage_2); Serial.println(" V");
  Serial.print("Shunt Voltage2: "); Serial.print(shuntvoltage_2); Serial.println(" mV");
  Serial.print("Load Voltage2:  "); Serial.print(loadvoltage_2); Serial.println(" V");
  Serial.print("Current2:       "); Serial.print(current_mA_2); Serial.println(" mA");
  Serial.print("Power2:         "); Serial.print(power_mW_2); Serial.println(" mW");
  Serial.println("");
 float shuntvoltage_3 = 0;// current voltage monitor 1
  float busvoltage_3 = 0;
  float current_mA_3 = 0;
  float loadvoltage_3 = 0;
  float power_mW_3 = 0;
  shuntvoltage_3 = ina219_C.getShuntVoltage_mV();
  busvoltage_3 = ina219_C.getBusVoltage_V();
  current_mA_3 = ina219_C.getCurrent_mA();
  power_mW_3 = ina219_C.getPower_mW();
  loadvoltage_3 = busvoltage_3 + (shuntvoltage_3 / 1000);
  Serial.print("Bus Voltage3:   "); Serial.print(busvoltage_3); Serial.println(" V");
  Serial.print("Shunt Voltage3: "); Serial.print(shuntvoltage_3); Serial.println(" mV");
  Serial.print("Load Voltage3:  "); Serial.print(loadvoltage_3); Serial.println(" V");
  Serial.print("Current3:       "); Serial.print(current_mA_3); Serial.println(" mA");
  Serial.print("Power3:         "); Serial.print(power_mW_3); Serial.println(" mW");
  Serial.println("");
delay(3000);
 if (Serial.available () )
char state = Serial.read();
  if (state=='H' || state=='h') // switch 1 on and off control
    digitalWrite(switch_1, HIGH);
    Serial.println("Switch 1 ON");
   if (state=='L' || state=='l')
    digitalWrite(switch_1, LOW);
    Serial.println("Switch 1 OFF");
   if (state=='W' || state=='w') // switch 2 on and off control
    digitalWrite(switch_2, HIGH);
    Serial.println("switch 2 ON");
   if (state=='E' || state=='e')
    digitalWrite(switch_2, LOW);
    Serial.println("switch 2 OFF");
   if (state=='A' || state=='a') // switch 3 on and off control
    digitalWrite(switch_3, HIGH);
    Serial.println("switch 3 ON");
   if (state=='S' || state=='s')
    digitalWrite(switch_3, LOW);
    Serial.println("switch 3 OFF");
criton07
Re: using multiple INA219 in a circuit
by adafruit_support_bill on Wed Jul 17, 2019 11:15 am
Please do not double post: viewtopic.php?f=25&t=117005#p760590
