I am trying to implement a DHT11 on my project for my students. I am using a Feather M4 Express, using CircuitPython 4.1, and using the latest libraries for that version. At the REPL, I typed in the following:
>>> import board
>>> import adafruit_dht
>>> a=adafruit_dht.DHT11(board.D5)
>>> a.temperature
I got the following error:
File "<stdin>", line 1, in <module>
File "/home/travis/build/adafruit/Adafruit_CircuitPython_Bundle/libraries/drivers/dht/adafruit_dht.py", line 227, in temperature
File "/home/travis/build/adafruit/Adafruit_CircuitPython_Bundle/libraries/drivers/dht/adafruit_dht.py", line 219, in measure
RuntimeError: DHT sensor not found, check wiring
I checked the wiring (tried both 3.3V and 5V at separate times to power the DHT11), and had the technician and another colleague verify the wiring. We also did a check on the pin D5, and it produced the proper timing (went from high to low for about 40 ms, and then went high . However, the data pin did not send out a response signal. I tested this with three DHT11s, and got the same result. Additionally, I used the previous 4.x library, and got the same result, except without the "/home/travis/build/adafruit/Adafruit_CircuitPython_Bundle/libraries/drivers/dht/ directory listing.
Any assistance would be greatly appreciated. Thank you for your time.
Best Regards,
Chris
DHT11 Assistance
- jerryn
Re: DHT11 Assistance
Do you have a pull-up resistor installed on the data line?
- cpeters1968
Yes. I have it connected between the power and data lines.
Thank you for your rapid response.
- jerryn
hmm - I realize that "it works for me" is not the most helpful response, but:
a few suggestions ... (from my own experiences)
Inspect all solder joints on the feather headers (the header is soldered, correct?)
Make sure your jumper wires are OK --try new ones.
If using breadboard - try different locations.
Make sure the DHT11 is oriented properly.
edited to add:
It may help to post a photo showing your wiring.
also note: I do not represent Adafruit - I'm another customer.
Adafruit CircuitPython 4.1.0 on 2019-08-02; Adafruit Feather M4 Express with samd51j19
>>> import board
>>> import adafruit_dht
>>> a.temperature
26
edited to add:
- cpeters1968
I used a new board, new wires, and verified the digital port was working by using an LED to test it. I still got the same result:
>>> a.temperature
Attached is a photo of my circuit. Thank you again.
Best Regards,
Chris
- dht.jpg (120.28 KiB) Viewed 3010 times
- jerryn
You need to connect a Ground wire.
I'm not sure your wiring is correct at all. see this page -- dht22 is the same as dht11 wiring
https://learn.adafruit.com/dht/dht-circuitpython-code
the pullup goes between data (pin2) and Power Pin1
pin 1 to 3.3V
pin 2 to D5
Pin 4 to ground
pin 1 to 3.3V
pin 2 to D5
Pin 4 to ground
- cpeters1968
Thanks for the reply. I guess the photo I attached was the three-pin version (with pins from left to right: data, power, and ground). I tried the four-pin version too, and had it connected as you said, but got the same thing.
It's weird, as I got the other two sensors working (CdS photoresistor and moisture sensor), but this one just seems to be giving me some issue.
- cpeters1968
So I did another diagnostic. I hooked up my 3-pin DHT11 to my Feather M0 Express, and got a good readout. Since both feathers use CircuitPython 4.1, I copied the libraries from the feather M0 to the M4. However, it came up with the following errors:
File "adafruit_dht.py", line 227, in temperature
File "adafruit_dht.py", line 219, in measure
I either get that error, or I get "None" at the readout.
I don't think I damaged my digital pins, as I can get a LED to light up.
- jerryn
odd, but that verifies the output, not the input. You may want to see if it can read a 0 and 1 when connected to GND and 3.3V on D5.
Otherwise, I'm out of ideas. Sorry, I was not familiar with the 3 Pin DHT11.
- cpeters1968
Thank you for your time. What library version are you using? I'm using the latest 4 that was released two or three days ago.
- jerryn
Yes -- it is the latest released version of adafruit_dht.
- jerryn
I forgot to check, Are the headers soldered to the feather m4?
Do you have link for the source of the 3 pin DHT?
- cpeters1968
Yes, the headers are soldered. I'm attaching an image for both 3 and 4 pin versions of the DHT. I did get the 3-pin to work on the M0. It's just when I replace the M0 with the M4 it doesn't work.
- jerryn
Sorry - I'm stumped.... I wish I had something else to offer other than verifying that the M4 input is working. You could just try a different input Pin.
- cpeters1968
I just had pin 13 send a 0 and 1 to pin 5, and pin 5 got the right value.
It's weird that this isn't working.
