I'm working with the Circuit Playground Express, and my students are starting to connect external neopixels to their boards. The Neopixel library is working great on its own, as is the circuit playground library. When I put both libraries into an Arduino sketch, it doesn't compile for the C.P.E. Is there a way to integrate both libraries on the same firmware, or to use the setPixelColor function on a different pin so that it works with externally connected Neopixels?
Circuit Playground Express, External Neopixels, and Arduino
- jmorri36
- Franklin97355
Re: Circuit Playground Express, External Neopixels, and Ardu
Post the code you are trying to compile and we can take a look. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and paste your code between the tags created.
- jmorri36
Weird, it only happens on one computer. The others compile fine. I'll try reinstalling the libraries and see if it works itself out.
- jmorri36
So I was just in class yesterday and the problem presented itself again on two other computers. What's happening is if I have one of the circuit playground example files loaded up it compiles fine, but if I just add the include neopixel library line it says "error compiling for circuit playground express." I tried updating both libraries, then removing and reinstalling them, but still got the error. Additionally, on one of the computers, the error comments were saying something about finding duplicate libraries like wire and spi. And just for reference, this was happening on both a Mac and PC. Any thoughts on how I could troubleshoot this issue?
- jmorri36
Copied the verbose error code that I'm getting from one student's computer. When I add the line to include the neopixel library, I get errors about duplicate libraries. I've reinstalled and made sure that everything is current for Arduino, the circuit playground and neopixel libraries, and the circuit playground express board. The code I'm running are just the example files for circuit playground, and I'm only putting in the Neopixel library just to test if it's the inclusion of the library that's causing the issue. Any thoughts on how to fix the issue?
Arduino: 1.8.10 (Windows 10), Board: "Adafruit Circuit Playground Express"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kelli\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kelli\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kelli\Documents\Arduino\libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -ide-version=10810 -build-path C:\Users\kelli\AppData\Local\Temp\arduino_build_981738 -warnings=none -build-cache C:\Users\kelli\AppData\Local\Temp\arduino_cache_6131 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -verbose C:\Users\kelli\Documents\Arduino\11.8withjoe\11.8withjoe.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\kelli\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\kelli\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\kelli\Documents\Arduino\libraries -fqbn=arduino:samd:adafruit_circuitplayground_m0 -ide-version=10810 -build-path C:\Users\kelli\AppData\Local\Temp\arduino_build_981738 -warnings=none -build-cache C:\Users\kelli\AppData\Local\Temp\arduino_cache_6131 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.bossac-1.7.0-arduino3.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3 -prefs=runtime.tools.openocd.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.10.0-arduino7 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.CMSIS-Atmel.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.CMSIS-Atmel-1.2.0.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0 -prefs=runtime.tools.arduinoOTA.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.2.1 -prefs=runtime.tools.CMSIS.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0 -verbose C:\Users\kelli\Documents\Arduino\11.8withjoe\11.8withjoe.ino
Using board 'adafruit_circuitplayground_m0' from platform in folder: C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4
Using core 'arduino' from platform in folder: C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4
Detecting libraries used...
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o nul
Alternatives for Adafruit_CircuitPlayground.h: [[email protected] [email protected]]
ResolveLibrary(Adafruit_CircuitPlayground.h)
-> candidates: [[email protected] [email protected]]
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o nul
Alternatives for SPI.h: [[email protected]]
ResolveLibrary(SPI.h)
-> candidates: [[email protected]]
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o nul
Alternatives for Wire.h: [[email protected]]
ResolveLibrary(Wire.h)
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o nul
Alternatives for Adafruit_NeoPixel.h: [[email protected]]
ResolveLibrary(Adafruit_NeoPixel.h)
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\Adafruit_CircuitPlayground.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_FreeTouch.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_LIS3DH.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_Mic.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_NeoPixel.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_CPlay_Speaker.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\Adafruit_ZeroPDM.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\CP_Firmata.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\CPlay_CapacitiveSensor.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibDecodeBase.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibHardware.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibProtocols.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibRecvBase.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibRecvPCI.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibSAMD21.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\IRLibSendBase.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\ffft.S" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground\\utility\\talkie.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI\\SPI.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire\\Wire.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel\\Adafruit_NeoPixel.cpp" -o nul
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel\\esp8266.c" -o nul
Generating function prototypes...
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10810 -DARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS -DARDUINO_ARCH_SAMD -DCRYSTALLESS -DARDUINO_SAMD_ZERO -D__SAMD21G18A__ -DUSB_VID=0x239A -DUSB_PID=0x8018 -DUSBCON "-DUSB_MANUFACTURER=\"Adafruit\"" "-DUSB_PRODUCT=\"Circuit Playground Express\"" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS\\4.5.0/CMSIS/Include/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\CMSIS-Atmel\\1.2.0/CMSIS/Device/ATMEL/" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\cores\\arduino" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\variants\\circuitplay" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_Circuit_Playground" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\SPI" "-IC:\\Users\\kelli\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\samd\\1.8.4\\libraries\\Wire" "-IC:\\Users\\kelli\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp" -o "C:\\Users\\kelli\\AppData\\Local\\Temp\\arduino_build_981738\\sketch\\11.8withjoe.ino.cpp.o"
In file included from C:\Users\kelli\Documents\Arduino\11.8withjoe\11.8withjoe.ino:3:0:
C:\Users\kelli\Documents\Arduino\libraries\Adafruit_NeoPixel/Adafruit_NeoPixel.h:151:52: error: redefinition of 'const uint8_t _NeoPixelSineTable [256]'
static const uint8_t PROGMEM _NeoPixelSineTable[256] = {
In file included from C:\Users\kelli\Documents\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_Circuit_Playground.h:21:0,
from C:\Users\kelli\Documents\Arduino\libraries\Adafruit_Circuit_Playground/Adafruit_CircuitPlayground.h:3,
from C:\Users\kelli\Documents\Arduino\11.8withjoe\11.8withjoe.ino:1:
C:\Users\kelli\Documents\Arduino\libraries\Adafruit_Circuit_Playground/utility/Adafruit_CPlay_NeoPixel.h:151:30: note: 'const uint8_t _NeoPixelSineTable [256]' previously defined here
C:\Users\kelli\Documents\Arduino\libraries\Adafruit_NeoPixel/Adafruit_NeoPixel.h:177:53: error: redefinition of 'const uint8_t _NeoPixelGammaTable [256]'
static const uint8_t PROGMEM _NeoPixelGammaTable[256] = {
C:\Users\kelli\Documents\Arduino\libraries\Adafruit_Circuit_Playground/utility/Adafruit_CPlay_NeoPixel.h:177:30: note: 'const uint8_t _NeoPixelGammaTable [256]' previously defined here
Multiple libraries were found for "SPI.h"
Used: C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4\libraries\SPI
Multiple libraries were found for "Wire.h"
Used: C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4\libraries\Wire
Multiple libraries were found for "Adafruit_NeoPixel.h"
Used: C:\Users\kelli\Documents\Arduino\libraries\Adafruit_NeoPixel
Multiple libraries were found for "Adafruit_CircuitPlayground.h"
Used: C:\Users\kelli\Documents\Arduino\libraries\Adafruit_Circuit_Playground
Not used: C:\Program
Using library Adafruit_Circuit_Playground at version 1.10.2 in folder: C:\Users\kelli\Documents\Arduino\libraries\Adafruit_Circuit_Playground
Using library SPI at version 1.0 in folder: C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\kelli\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.4\libraries\Wire
Using library Adafruit_NeoPixel at version 1.3.1 in folder: C:\Users\kelli\Documents\Arduino\libraries\Adafruit_NeoPixel
exit status 1
Error compiling for board Adafruit Circuit Playground Express.
- jmorri36
franklin97355 wrote:Post the code you are trying to compile and we can take a look. Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and paste your code between the tags created.
Figured out the problem, and I'm not sure that the solution is listed in the C.P.E. guides. If you're using the circuit playground library and the neopixel library in the same sketch, it wont compile unless the neopixel library is included before the circuit playground library. If it's done in reverse, it generates errors. Code's working just fine now.
- Franklin97355
Thank you for posting your solution. I'll make sure the author is aware of your findings.
- adafruit2
