My code Webserver does not show bme280 sensor data in esp32, of my weather station.
Here is the code that I'm using:
#include "ETH.h"
#include <WiFi.h>
#include <WiFiAP.h>
#include <WiFiGeneric.h>
#include <WiFiMulti.h>
#include <WiFiScan.h>
#include <WiFiSTA.h>
#include <WiFiType.h>
#include <ssl_client.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#include <WiFiClientSecure.h>
#include <Wire.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <SPI.h>
#include "WiFi.h"
// BME280
#define SEALEVELPRESSURE_HPA (1013.25)
#define BME_SCK 18
#define BME_MISO 19
#define BME_MOSI 23
#define BME_CS 2
Adafruit_BME280 bme (BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
float Temperature;
float Humidity;
float Pressure;
float Altitude;
// Webserver
const char* ssid = "Name";
const char* password = "password";
WiFiServer server(80);
//Gy521
#include<Wire.h>
const int MPU_addr=0x68; // I2C address of the MPU-6050
int AcX;
int AcY;
int AcZ;
int Tmp;
int GyX;
int GyY;
int GyZ;
//Funções
void bmereading() {
Temperature = bme.readTemperature();
Humidity = bme.readHumidity();
Pressure = bme.readPressure() / 100.0F;
Altitude = bme.readAltitude(SEALEVELPRESSURE_HPA);
void Connect_WiFi(){
WiFi.begin(ssid, password);
while(WiFi.status() != WL_CONNECTED)
delay(100);
void Gy(){
Wire.beginTransmission(MPU_addr);
AcX = Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Tmp = Wire.write(0x41);
AcY = Wire.write(0x3D);
AcZ = Wire.write(0x3F);
GyX = Wire.write(0x43);
GyY = Wire.write(0x45);
GyZ = Wire.write(0x47);
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,7*2,true); // request a total of 14 registers
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
void setup()
Wire.begin();
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
Serial.begin(115200);
bool status;
status = bme.begin(0x76);
delay(10000);
Serial.print("Setting soft access point mode");
WiFi.softAP(ssid, password);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
server.begin();
void loop()
WiFiClient client=server.available();
// Display the HTML web page
void bmereading();
void Gy();
client.print("<html>");
client.print ("<head>");
client.print ("<title> Bar </title>");
client.print ("</head>");
client.print("<body>");
client.print ("<h1> My Kind of Bar </h1>");
client.println("<p> Temperature: </p>");
client.println(bme.readTemperature());
client.println(" *C \n");
client.print("<p> Temperature in *F: </p>");
client.print(Tmp); //equation for temperature in degrees C from datasheet
client.println(" *F \n");
client.println("<p> Humidity: </p>");
client.println(bme.readHumidity());
client.println("% \n");
client.println("<p> Pressure: </p>");
client.println(bme.readPressure());
client.println("hPa \n");
client.println("<p> Approx Altitude: </p>");
client.println (bme.readAltitude(SEALEVELPRESSURE_HPA));
client.println("m \n");
client.println("<p>Acelerometer in X: </p>");
client.print(AcX );
client.println("<p>Acelerometer in Y: </p>");
client.print(AcY);
client.println("<p>Acelerometer in Z: </p>");
client.print(AcZ);
client.println("<p>Gyroscope in X: </p>");
client.print(GyX);
client.println("<p>Gyroscope in Y: </p>");
client.print(GyY);
client.println("<p> Gyroscope in Z: </p> ");
client.println(GyZ);
client.print ("</body>");
client.print ("</html>");
