Integrating LED and Button
by drbrunner on Sat May 02, 2020 2:54 am
I am relatively new to this area (adafruit, arduino etc).
I have completed the first few adafruit projects with my class (https://learn.adafruit.com/welcome-to-a ... o/projects) with a lot of success.
I wanted to try to integrate the first two (a button and an LED) together onto a single board. This would mean I would press a button and turn on an LED - simple - but it would via the adafruit feeds.
See code below for my "integration" of the two.
The end result is that it builds, the button works (communicates with the digital feed) but there is no communication the other way - so there is no message received from adafruit that a change has occurred on the feed and the LED does not turn on.
I suspect this might just not work because it is sending the return message at almost the same time that I am uploading the button information... but I am not sure. Any help appreciated. Thank you.
LEDButtonCombine.zip
(2.7 KiB) Downloaded 2 times
drbrunner
