wave shield - won't play music
by efeigenbaum on Sun May 03, 2020 2:38 pm
Hi. I need some help. I am trying to play music from an SD card using the audio shield for my arduino uno. I converted a file from an mpeg in iTunes to a wave file. When I run the daphc example file from the WaveHC library - I get the following error message:
Playing _S~1.WAVDVOLUME must be set to non-zero in WaveHC.h
Not a valid WAV
What might I be doing wrong and how might I fix it?''
I think my SD card is formatted correctly, but I am sort of new to this.
Thanks.
efeigenbaum
Re: wave shield - won't play music
by kevinjwalters on Wed Jun 10, 2020 8:35 pm
Did you try this with other samples to see if they work ok? The ones in https://github.com/adafruit/WaveHC/tree/master/ (look in the Files For Examples sub directory) look like a good starting point as they are ancillary files in the library's repository.
kevinjwalters
by efeigenbaum on Thu Jun 11, 2020 5:42 am
I finally found some files that work. Thanks.
efeigenbaum
