Adafruit Ultimate GPS FeatherWing MTK3339
by JoanCS on Wed May 20, 2020 7:11 am
Good morning. In reading longitude and latitude, they have an incorrect reading. It returns the latitude to me with 5 digits !!!
What is my mistake?
Is it normal for speed not to mark me zero?
Time: 11:01:42.41520
Date: 20/5/2020
Fix: 1 quality: 1
Speed (knots): 0.27
Speed (Km/h): 0.50
Angle: 331.60
Altitude: 564.90
Satellites: 8
JoanCS
Re: Adafruit Ultimate GPS FeatherWing MTK3339
by JoanCS on Thu May 28, 2020 11:42 am
Good afternoon.
I can't figure out how to fix this. It happens to me both in latitude and in longitude.
He may be doing the readings well for a good while and suddenly he starts making some misreadings.
Any idea how I can fix it?
thanks.
JoanCS
by adafruit_support_bill on Thu May 28, 2020 11:48 am
Which Feather are you using this with?
Can you post some more data - showing both good and bad readings?
by JoanCS on Thu May 28, 2020 11:57 am
Attached is an image of two misreadings but I have already treated them with software.
Also the piece of code I use to do the reading. Where I already discard the erroneous LAT but not the erroneous LON.
Data is already coming in wrong from GPS. There are some ways to get the coordinates in format
GD (decimal degrees) directly from GPS?
 char c = GPS.read();
  if (GPS.newNMEAreceived())
    if (!GPS.parse(GPS.lastNMEA()))   // this also sets the newNMEAreceived() flag to false
      return;  // we can fail to parse a sentence in which case we should just wait for another
  if (millis() - timer > 2000) {
    timer = millis(); // reset the timer
    if (GPS.hour < 10) { Serial.print('0'); }
    Serial.print(GPS.hour, DEC); Serial.print(':');
    if (GPS.minute < 10) { Serial.print('0'); }
    Serial.print(GPS.minute, DEC); Serial.print(':');
    if (GPS.seconds < 10) { Serial.print('0'); }
    Serial.print(GPS.seconds, DEC); Serial.print('.');
    if (GPS.milliseconds < 10) {
      Serial.print("00");
    } else if (GPS.milliseconds > 9 && GPS.milliseconds < 100) {
      Serial.print("0");
    Serial.println(GPS.milliseconds);
    Serial.print("Date: ");
    Serial.print(GPS.day, DEC); Serial.print('/');
    Serial.print(GPS.month, DEC); Serial.print("/20");
    Serial.println(GPS.year, DEC);
    Serial.print("Fix: "); Serial.print((int)GPS.fix);
    Serial.print(" Quality: "); Serial.println((int)GPS.fixquality);
    if (GPS.fix)
      Serial.println("GPS --------->");
      Serial.print("Location: ");
      Serial.print(GPS.latitude, 4); Serial.print(GPS.lat);
      Serial.print(", ");
      Serial.print(GPS.longitude, 4); Serial.println(GPS.lon);
      Serial.print("Speed (knots): "); Serial.println(GPS.speed);
      Serial.print("Angle: "); Serial.println(GPS.angle);
      Serial.print("Altitude: "); Serial.println(GPS.altitude);
      Serial.print("Satellites: "); Serial.println((int)GPS.satellites);
      LAT = 0;   //LAT = 4151.2124;  //Ausate
      LON = 0;   //LON = 214.3523;
      LAT = GPS.latitude;
      if ((int)GPS.fixquality < 2 )
        goto Error;
      if (LAT > 8999)   //ERROR DE LAT ????????
        LAT=4151.1962;
        goto Error;
      LON = GPS.longitude;
      ftoa(strLat,LAT, 4);
      ftoa(strLon,LON, 4);
      LatLon=1;
      if (GPS.lat = "N" )  //LAT N
        LatconvertMinSecDeg(strLat,0);
      else
        LatconvertMinSecDeg(strLat,1);  //LAT S
      LatLon=2;
      if (GPS.lon = "S")  //LON
        LatconvertMinSecDeg(strLon,0);
      else
        LatconvertMinSecDeg(strLon,1);  //LON W
lecturesERROR GPS.png (6.67 KiB) Viewed 830 times
JoanCS
by adafruit_support_bill on Thu May 28, 2020 12:06 pm
Please post some of the raw NMEA sentences - without any parsing or conversion.
by JoanCS on Thu May 28, 2020 12:17 pm
Model:
Ultimate GPS FeatherWing)
NMEA -->
$PGTOP,11,2*6E
$GPGGA,162518.000,41515.2147,N,00214.3828,E,2,03,2.33,613.4,M,51.1,M,0000,0000*65
$GPRMC,162518.000,A,41515.2147,N,00214.3828,E,0.64,187.65,280520,,,D*67
JoanCS
by adafruit_support_bill on Thu May 28, 2020 12:25 pm
Model:
That is just the GPS wing. What processor are you using to read and parse the data from it?
by adafruit_support_bill on Thu May 28, 2020 12:28 pm
NMEA --> exemple:
$GPRMC,194509.000,A,4042.6142,N,07400.4168,W,2.03,221.11,160412,,,A*77
Please post more raw readings - showing both good and bad data.
by JoanCS on Thu May 28, 2020 12:53 pm
Adafruit Feather con microcontrolador ATMega32U4 y módulo GSM FONA SIM800
and
I have it connected to an 18000m Lipo battery
Strange things are happening to me. From time to time it is prescribed, etc ..
I am trying to match GPS data with good data and errors.
Now I can't get it to fail !!!
$PGTOP,11,2*6E
$GPGGA,165236.000,4151.2125,N,00214.3634,E,1,08,1.12,616.2,M,51.1,M,,*65
$GPRMC,165236.000,A,4151.2125,N,00214.3634,E,0.29,14.84,280520,,,A*54
$PGTOP,11,2*6E
$GPGGA,165237.000,4151.2124,N,00214.3637,E,1,08,1.12,616.2,M,51.1,M,,*66
$GPRMC,165237.000,A,4151.2124,N,00214.3637,E,0.24,39.57,280520,,,A*5B
JoanCS
by Josh_1 on Thu May 28, 2020 12:59 pm
I'm working with the same project as @JoanCS. With a 100km between his prototype and mine. And I'm having the same issues.
We are using: Adafruit Ultimate GPS featherwing, plugged on Adafruit Feather 32u4 FONA. I have my own both Feathers and @JoanCS have his own both Feathers.
The base of our porgram is tooked from (https://learn.adafruit.com/adafruit-ult ... no-library) and I think the problem is inside the library Adafruit_GPS→GPS_HardwareSerial_Parsing. Because the RAW NMEA sentences are correct but not the library convertion values.
Here the example wich I tooked 10 mins ago:
Josh_1
by adafruit_support_bill on Thu May 28, 2020 1:12 pm
Thank you for the additional information. I agree, it looks like the NMEA sentences appear to be getting parsed incorrectly.
Are you using the hardware serial or software serial to talk to the module?
Does your program also communicate with the FONA module - or are you just reading GPS data?
by JoanCS on Thu May 28, 2020 1:14 pm
My program communicates with FONA and GPS.
I start to have doubts if I chose the right material. There are times when I think communications get mixed up. But it is an intuition.
JoanCS
by adafruit_support_bill on Thu May 28, 2020 1:19 pm
I suspect that some characters are getting dropped on the serial port when you are communicating with the FONA. The FONA communicates via SoftwareSerial and will disable interrupts while processing received characters. This can cause characters from the GPS to be dropped - resulting in a corrupted NMEA sentence.
by JoanCS on Thu May 28, 2020 1:27 pm
What solution can I apply?
Is there any way for the GPS to return the data to me in my format? decimal degrees?
JoanCS
by Josh_1 on Thu May 28, 2020 1:35 pm
adafruit_support_bill wrote:Thank you for the additional information. I agree, it looks like the NMEA sentences appear to be getting parsed incorrectly.
Hello, your welcome for your fast responses.
We are using the HardwareSerial, the Serial1 to receive the information.
Related with the question: Does your program also communicate with the FONA module - or are you just reading GPS data?: We are just takeing the procesed information of the library and with this information we are doing some conversions of values to adapt on our sistem and after that build and URL to upload the values on a server via AT comands.
Let me point that we are not working with raw NMEA cuz how we had the Adafruit library wich that break them into separate parts and makes our job easier. But we saw this problem that more than the 50% of readings on Latitude or Longitude apears an extra value. And all time apears in the same position. I mean if the Raw Latitude is 4444.4444N the random extra digit apears all times before point, 4444X.4444N, being the other numbers correct.
Josh_1
