I have constructed a UVC Sterilizer using an old microwave oven and a UVC water purification lamp, and I need a way to accurately measure its 254nm output that doesn't involve access to an expensive UV photometer. (See project build at: https://www.greenequitybuilders.org/pdfs/UV_Box.pdf)
I saw the 1918 ANALOG UV SENSOR BREAKOUT Board and that looked promising except that it has very poor sensitivity in the germicidal UVC wavelength range.
But then I saw that the GUVC-S10GD photodiode has a spectral range of 220nm - 280nm, which is ideal!
Does anyone know if the GUVA-S12SD photodiode on the 1918 ANALOG UV SENSOR BREAKOUT Board could be de-soldered and replaced with the GUVC-S10GD photodiode (or the GUVC-S40GD, or something similar) to get a better UVC sensor breakout board for germicidal UVC projects?
(I suspect that a lot of makers would like to certify their Covid-19 UVC projects right about now.)
