CircuitPython NeoPixel Guide
by ZippyFace on Fri May 22, 2020 6:52 pm
I haven't used Adafruit products or programmed in CircuitPython before.
I'm trying to follow the guide at this link: https://learn.adafruit.com/adafruit-gem ... neopixel-2 to control a series of NeoPixels on a strip but I cannot get the LEDs to light up like they should.
I've taken these steps to set up my board and try to run the code:
1. Downloaded the latest drivers for my board (GEMMA MO)
2. Downloaded and installed the latest CircuitPython so my computer recognizes my board as CIRCUITPY when I plug it into the USB drive
3. Successfully ran the sample code given here: https://learn.adafruit.com/adafruit-gem ... iting-code to verify that I can control the LED mounted on the board
4. Downloaded the latest library bundle and placed the necessary library file (neopixel.mpy) into the lib folder on my board
5. Pasted the sample code from the guide in the first link above for controlling the NeoPixel strip into Mu and saved it to my board
6. Used alligator clips to connect a section of 8 LEDs from a NeoPixel stip to the GEMMA as shown on the circuit diagram given in the guide
Obviously, I've done something wrong or missed a step but I've reviewed the setup steps multiple times and I can't seem to figure this out. Perhaps I just need to restart the process from scratch.
Any advice?
Thank you in advance!
ZippyFace
Re: CircuitPython NeoPixel Guide
by adafruit_support_carter on Fri May 22, 2020 7:23 pm
What filename did you use here?
by ZippyFace on Fri May 22, 2020 8:54 pm
The filename I used was NeoPixelDemo.py
ZippyFace
by adafruit_support_carter on Tue May 26, 2020 10:38 am
To have the program run automatically, you'll need to give it one of these names:
https://learn.adafruit.com/welcome-to-c ... 2977482-35
by ZippyFace on Wed May 27, 2020 5:35 pm
Thank you, I don't know how I missed that. After using the correct filename, the lights still do not light up. the onboard LED flashes green, then yellow once, then there's a space, then blue 4 times. I looked at the troubleshooting page for GEMMA MO but this sequence of flashes doesn't seem to indicate a line in my code. Also, I copied the code from the tutorial page.
ZippyFace
by adafruit_support_carter on Wed May 27, 2020 5:46 pm
That sounds like it might be one of these status indicator patterns?
https://learn.adafruit.com/welcome-to-c ... 2978455-20
by ZippyFace on Wed Jun 03, 2020 11:26 am
Thank you for your response. After reading your post, I spent more time trying to understand the RGB status light. The link you sent me states
"Colors with multiple flashes following indicate a Python exception and then indicate the line number of the error. The color of the first flash indicates the type of error"
And then it says that a green flash indicates an indentation error. But, as I purposefully put errors in my code to see how it changed the flashes, I realized that the first green flash must indicate that code is running but doesn't indicate an error. After realizing that, I could see that the other flashes I was getting (yellow followed by four cyan) indicate "other error" on line 4 of my code. Line 4 is:
import neopixel
I'm confused why this line is returning an error because I already put the neopixel.mpy file in my lib folder on the GEMMA MO. I'm confident that I downloaded the correct library for my version of CircuitPython. Could there be another reason this line is giving me an error?
ZippyFace
by adafruit_support_carter on Wed Jun 03, 2020 1:45 pm
To get a better read out of the error, try running things interactively via REPL (the CircuitPython prompt). Click the Serial button and then in the lower window, get to the >>> prompt and then try the import statement:
by ZippyFace on Wed Jun 03, 2020 2:59 pm
Thank you, that helps. The serial console helped me figure out the issue. There is another library needed to run the code in the tutorial I was following but it isn't specified in the instructions (https://learn.adafruit.com/adafruit-gem ... neopixel-2). The additional library file that is needed is adafruit_pypixelbuf.mpy. It is used by the neopixel.mpy library.
The code works after copying adafruit_pypixelbuf.mpy to the GEMMA lib folder. Thanks again!
ZippyFace
by adafruit_support_carter on Wed Jun 03, 2020 5:30 pm
Cool. Glad that worked.
That Serial window trick is useful for helping figure out what is going on. Another way it might have worked would be to have it opened while your code ran. In the screen shot above, you can see it says:
code.py output:
and then the results of the code running. In that example it isn't too exciting. But it would have also printed the text of the error message when it happened.
Have fun!
