Adafruit Ultimate GPConvert coordinates to decimal formatS F
by JoanCS on Thu Jun 25, 2020 4:58 am
Good morning. The plate "Adafruit Ultimate GPS FeatherWing MTK3339"
It gives me the coordinates in this format: 4151.0869N and 214.37690E. I need the conversion to decimal format: 41.8537250 and 2.2391250.
I have made a function but it is little optimized and uses a lot of memory. Does anyone have an optimal function to do the transformation?
I attach the code of my function.
Thank you.
      LAT = 0;   //LAT = 4151.2124;
      LON = 0;   //LON = 214.3523;
      LAT = GPS.latitude;
      LON = GPS.longitude;
      if ((int)GPS.fixquality < 1 )
        goto Error;
      if (LAT > 8999)
        LAT=4151.1962;
        goto Error;
      if (LON > 999)   //aquesta condicio no es bona !!!
        LON=213.9104;
        goto Error;
      ftoa(strLat,LAT, 4);
      ftoa(strLon,LON, 4);
      LatLon=1;
      if (GPS.lat == 78 )  //LAT N nord, ascii N = 78
        LatconvertMinSecDeg(strLat,0);
      else
        LatconvertMinSecDeg(strLat,1);  //LAT S
      LatLon=2;
      if (GPS.lon == 69)  //LON  E Sud, ascii E = 69
        LatconvertMinSecDeg(strLon,0);
      else
        LatconvertMinSecDeg(strLon,1);  //LON W
void LatconvertMinSecDeg(char *DecMinuts, int PosNeg)    //Decimal Degrees = degrees + (minutes/60) + (seconds/3600)
  //4151,1962N = 41+(51,1962 / 60) = 41.85327
  //213,9163E = 2+(13,9163 / 60) = 2.23193
  float DDDD = 0;
  float MMMM = 0;
  float Total = 1;
  int DD = 0;
  int RM = 0;
  char *s;
  int aa=0;
  delay(500);
  s = strtok( DecMinuts, ".");
  while (s!=NULL)
    if (aa==0)
    DDDD = atol(s);
    aa=1;
    else
    MMMM = atol(s);
    s=strtok(NULL, ".");
  DD = DDDD / 100;
  RM = fmod(DDDD, 100);
  if (PosNeg == 1)
    Total = -1;
  Total = Total * (DD+((RM + (MMMM / 10000))/60));
  String Var;
  //Var = floatToString(Total,10,9,false);
  Var = floatToString(Total,10,8,false);
  if (LatLon == 1) Var.toCharArray(strLat, Var.length());
  if (LatLon == 2) Var.toCharArray(strLon, Var.length());  //pasem de String a Char
  //strcat(strLat, "41.85327");
  //strcat(strLon, "2.23193");
String floatToString( float n, int l, int d, boolean z)
 char c[l+1];
 String s;
 dtostrf(n,l,d,c);
 s=String(c);
 if(z)
 s.replace(" ","0");
 return s;
JoanCS
Re: Adafruit Ultimate GPConvert coordinates to decimal forma
by JoanCS on Mon Jun 29, 2020 5:31 am
Good morning.
I have improved the function a bit and function better.
// Funció que converteix les coordenades que rep el GPS a "decimal degrees ***********************************************
  //4151,1962N = 41+(51,1962 / 60) = 41.85327   i 213,9163E = 2+(13,9163 / 60) = 2.23193
  float DDDD = 0;
  float MMMM = 0;
  float Total = 1;
  int DD = 0;
  int RM = 0;
  char *s;
  int aa=0;
  String Var="";
  delay(200);
  strcat(DecMinuts, ".");
  while (s!=NULL)
    if (aa==0)
    DDDD = atol(s);
    aa=1;
    else
    MMMM = atol(s);
  DD = DDDD / 100;
  if (PosNeg == 1)
    Total = -1;  // es que es S o W, ho passem a negatiu
  if (LatLon == 1) dtostrf(Total, 3, 7, strLat);
  if (LatLon == 2) dtostrf(Total, 3, 7, strLon);
// Fi funció que converteix les coordenades que rep el GPS a "decimal degrees *********************************************
JoanCS
