Stacking multiple hats via raspberry pi 3/4
by R_Henderson on Mon Jul 20, 2020 3:26 pm
I am trying to build a low cost flight data logger and I was wondering if you could stack the Adafruit Ultimate GPS Hat and the Raspberry Pi SenseHat using the extended (extra-long) header pins on one Raspberry Pi 3/4 to record and log all of the flight data. (GPS, ground speed, Temperature, Barometric pressure, Humidity, etc)
Thank you.
R_Henderson
Re: Stacking multiple hats via raspberry pi 3/4
by dastels on Mon Jul 20, 2020 5:13 pm
The GPS hat uses Tx/Rx which the Sensehat doesn't so that's ok. However both use pins 27 & 28 on the GPIO header (I2C bus) to access the onboard EEPROM chips that hold each board's identification info. Both boards use a CAT24C32 chip for this, and both have all three address pins grounded so they'll be at the same I2C address. This presents a problem.
I don't know off-hand how you would get around that, or if you even could.
dastels
by dastels on Mon Jul 20, 2020 5:19 pm
One alternative is to use the sensehat along with an Ultimate GPS breakout https://www.adafruit.com/product/746 which only uses Tx/Rx. The only challenge then would be to hijack those connections.
Going further, you could use the USB version of the breakout https://www.adafruit.com/product/4279 which plugs into one of the Pi's USB ports.
dastels
by R_Henderson on Wed Jul 29, 2020 2:57 pm
Thank you for your input.
I went with your second option, using the USB connection. It just arrived today. I will let you know how it goes.
A second USB breakout could be used to attach a second external temperature sensor to the raspberry pi/sense hat set-up, correct?
Thanks again for you help and input. It is greatly appreciated!
R
R_Henderson
by dastels on Wed Jul 29, 2020 3:30 pm
I assume a second USB breakout would work fine; it'll show up on a different tty device.
dastels
by R_Henderson on Wed Jul 29, 2020 4:00 pm
Awesome! Thanks!!
Another Adafruit purchase!! :)
Hopefully, I can combine all of the different input devices in to one python file.
R_Henderson
