I have just received an RGG 32 x64 Matrix LED with adafruit shield and arduino Metro M0 board. I have downloaded the libraries, RGB Matrix Panel and AdafruitBusIO, run the sample testshaps_32x64 program, bit LED RGB Matrix not running up, No circuit diagrams are available for troubleshooting the LED Matrix. How can I found out if the Matrix is faulty or not ?
I urgently need to use this matrix for demo purposes.
Thank you.
RGB 32 x64 Matrix not Working using arduino metro.
- clv001
Re: RGB 32 x64 Matrix not Working using arduino metro.
Please post some photos showing all of your soldering and connections.
- clv001
Please find attached the photoes. There are no shorts between pins, The Metro M0 board is working because I used it with ADAfruit LCD.. I am not able to check the 64x32 RGB Matrix.
If you can send me a working test program will be great I try it out.
Thank you.
Thank you.
- WhatsApp Image 2020-11-25 at 15.40.17.jpeg (124.41 KiB) Viewed 4971 times
- WhatsApp Image 2020-11-25 at 15.41.15.jpeg (104.54 KiB) Viewed 4971 times
- WhatsApp Image 2020-11-25 at 15.40.50.jpeg (90.12 KiB) Viewed 4971 times
- clv001
I am including some more pictures. Matrix remains fully blank altough 5V is available on the Power terminal of the shield and power socket of matrix.
- WhatsApp Image 2020-11-25 at 15.58.52.jpeg (160.61 KiB) Viewed 4970 times
- WhatsApp Image 2020-11-25 at 15.45.00.jpeg (112.95 KiB) Viewed 4970 times
I don't see any soldering issues. Double-check the connector orientation on the panel. The key on the connector should face out toward the edge of the matrix panel.
- clv001
The key is also in the correct orientation, inserted in the Input socket of matrix connector. I am using the following program but nothing works.
/ testshapes demo for RGBmatrixPanel library.
// Demonstrates the drawing abilities of the RGBmatrixPanel library.
// For 32x64 RGB LED matrix.
// WILL NOT FIT on ARDUINO UNO -- requires a Mega, M0 or M4 board
#include <RGBmatrixPanel.h>
// Most of the signal pins are configurable, but the CLK pin has some
// special constraints. On 8-bit AVR boards it must be on PORTB...
// Pin 11 works on the Arduino Mega. On 32-bit SAMD boards it must be
// on the same PORT as the RGB data pins (D2-D7)...
// Pin 8 works on the Adafruit Metro M0 or Arduino Zero,
// Pin A4 works on the Adafruit Metro M4 (if using the Adafruit RGB
// Matrix Shield, cut trace between CLK pads and run a wire to A4).
#define CLK 8 // USE THIS ON ADAFRUIT METRO M0, etc.
//#define CLK A4 // USE THIS ON METRO M4 (not M0)
//#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE 9
#define LAT 10
#define A A0
#define B A1
#define C A2
#define D A3
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false, 64);
matrix.begin();
// draw a pixel in solid white
matrix.drawPixel(0, 0, matrix.Color333(7, 7, 7));
delay(500);
// fix the screen with green
matrix.fillRect(0, 0, matrix.width(), matrix.height(), matrix.Color333(0, 7, 0));
delay(500);
// draw a box in yellow
matrix.drawRect(0, 0, matrix.width(), matrix.height(), matrix.Color333(7, 7, 0));
delay(500);
// draw an 'X' in red
matrix.drawLine(0, 0, matrix.width()-1, matrix.height()-1, matrix.Color333(7, 0, 0));
matrix.drawLine(matrix.width()-1, 0, 0, matrix.height()-1, matrix.Color333(7, 0, 0));
delay(500);
// draw a blue circle
matrix.drawCircle(10, 10, 10, matrix.Color333(0, 0, 7));
delay(500);
// fill a violet circle
matrix.fillCircle(40, 21, 10, matrix.Color333(7, 0, 7));
delay(500);
// fill the screen with 'black'
matrix.fillScreen(matrix.Color333(0, 0, 0));
// draw some text!
matrix.setTextSize(1); // size 1 == 8 pixels high
matrix.setTextWrap(false); // Don't wrap at end of line - will do ourselves
matrix.setCursor(8, 0); // start at top left, with 8 pixel of spacing
uint8_t w = 0;
char *str = "AdafruitIndustries";
for (w=0; w<8; w++) {
matrix.setTextColor(Wheel(w));
matrix.print(str[w]);
matrix.setCursor(2, 8); // next line
for (w=8; w<18; w++) {
matrix.println();
//matrix.setTextColor(matrix.Color333(4,4,4));
//matrix.println("Industries");
matrix.setTextColor(matrix.Color333(7,7,7));
matrix.println("LED MATRIX!");
// print each letter with a rainbow color
matrix.setTextColor(matrix.Color333(7,0,0));
matrix.print('3');
matrix.setTextColor(matrix.Color333(7,4,0));
matrix.print('2');
matrix.setTextColor(matrix.Color333(7,7,0));
matrix.print('x');
matrix.setTextColor(matrix.Color333(4,7,0));
matrix.print('6');
matrix.setTextColor(matrix.Color333(0,7,0));
matrix.print('4');
matrix.setCursor(34, 24);
matrix.setTextColor(matrix.Color333(0,7,7));
matrix.print('*');
matrix.setTextColor(matrix.Color333(0,4,7));
matrix.print('R');
matrix.setTextColor(matrix.Color333(0,0,7));
matrix.print('G');
matrix.setTextColor(matrix.Color333(4,0,7));
matrix.print('B');
matrix.setTextColor(matrix.Color333(7,0,4));
matrix.print('*');
// whew!
// Do nothing -- image doesn't change
// Input a value 0 to 24 to get a color value.
// The colours are a transition r - g - b - back to r.
uint16_t Wheel(byte WheelPos) {
if(WheelPos < 8) {
return matrix.Color333(7 - WheelPos, WheelPos, 0);
} else if(WheelPos < 16) {
WheelPos -= 8;
return matrix.Color333(0, 7-WheelPos, WheelPos);
} else {
WheelPos -= 16;
return matrix.Color333(WheelPos, 0, 7 - WheelPos);
Last edited by adafruit_support_bill on Wed Nov 25, 2020 11:40 am, edited 1 time in total.
Reason: Pleas use [code] tags when posting code to the forums
OK. We can try replacing the panel. Please contact [email protected] with a link to this thread and we can get one out to you.
- clv001
I have proceeded as instructed. Thank you again for your help.
- blnkjns
You can always try these panels without powersupply, just with USB power first. Make sure you only light up a few pixels at a time. so you stay under 500mA. I managed to run Pac-Man from USB power at 20% brightness. That way you can ensure it is not a problem of conflicting power sources.
- labtec21
clv001,
Did you ever get a replacement and if so did it fix the problem?
I am having the same problem with mine also. I checked the solder joints, connections. I am using the switching power supply 5v at 4 a. I checked the voltage leaving the shield going to the matrix with the matrix attached and it is reading 4.1 volts. I wonder if the voltage regulator on the metro M0 is defective and/or matrix is bad.
thanks for answering if a replacement corrected the situation.
@labtec21 - please post photos showing your soldering and connections.
- labtec21
Here are the pics requested
- 20210524_144815.jpg (943.42 KiB) Viewed 4110 times
- 20210524_144349.jpg (965.51 KiB) Viewed 4110 times
- labtec21
- 20210524_145519.jpg (881.26 KiB) Viewed 4110 times
- 20210524_145449.jpg (370.64 KiB) Viewed 4110 times
- 20210524_144906.jpg (908.09 KiB) Viewed 4110 times
- labtec21
- 20210524_145610.jpg (915.96 KiB) Viewed 4110 times
- labtec21
- 20210524_144321.jpg (367.77 KiB) Viewed 4110 times
