RGB 32 x64 Matrix not Working using arduino metro.
Re: RGB 32 x64 Matrix not Working using arduino metro.
by adafruit_support_bill on Mon May 24, 2021 4:52 pm
The assembly looks fine. Measure the voltage between the GND and VIN pins on the shield.
by labtec21 on Mon May 24, 2021 5:04 pm
here is the voltage - vin and grn.
labtec21
by adafruit_support_bill on Mon May 24, 2021 5:18 pm
Have you tried powering from USB as described here? viewtopic.php?f=48&t=172215#p842252
The dropout voltage for the regulator on the M0 can easily exceed 1v under load.
by labtec21 on Thu May 27, 2021 4:03 am
it doesn't light up any led using that method.
labtec21
by adafruit_support_bill on Thu May 27, 2021 4:56 am
What voltage do you see at the panel when powered via USB?
by labtec21 on Thu May 27, 2021 10:33 am
here the voltage measured at the input to the matrix
labtec21
by adafruit_support_bill on Thu May 27, 2021 10:44 am
OK. It looks like everything is assembled and connected right and you have good power. That leaves the matrix itself. We can try replacing it. Please contact support@adafruit.com with a link to this thread.
