Circuit board mounting
by davidturpin on Thu Mar 04, 2021 1:58 pm
I am new to this. Just wondered, with these very small circuit boards, such as the FX soundboard and some of the small voltage regulators, what to people use to mount them or keep them safe/still on a project??
David
davidturpin
Re: Circuit board mounting
by franklin97355 on Fri Mar 05, 2021 1:04 pm
Most of the boards have small mounting holes and the pins can be used to support them. If you need more than that the usual method is to use double-sided foam tape.
franklin97355
by davidturpin on Sun Mar 07, 2021 4:34 pm
Thank you!!
davidturpin
by fujito on Sat Jun 12, 2021 3:10 pm
franklin97355 wrote:Most of the boards have small mounting holes and the pins can be used to support them. If you need more than that the usual method is to use double-sided foam tape.
davidturpin wrote:Hi,
David
I just purchased a T4 Receiver. I don't see any mounting holes.
fujito
by adafruit_support_bill on Sat Jun 12, 2021 3:24 pm
The T4 board is not one of our designs and we don't manufacture them in-house. Double-sided foam-tape is a good mounting option for these.
