I am new to this. Just wondered, with these very small circuit boards, such as the FX soundboard and some of the small voltage regulators, what to people use to mount them or keep them safe/still on a project??
David
Circuit board mounting
- Franklin97355
Re: Circuit board mounting
Most of the boards have small mounting holes and the pins can be used to support them. If you need more than that the usual method is to use double-sided foam tape.
- fujito
franklin97355 wrote:Most of the boards have small mounting holes and the pins can be used to support them. If you need more than that the usual method is to use double-sided foam tape.
I just purchased a T4 Receiver. I don't see any mounting holes.davidturpin wrote:Hi,
David
The T4 board is not one of our designs and we don't manufacture them in-house. Double-sided foam-tape is a good mounting option for these.
