MCP3008 Double Ended Input ??
by BillPretty on Sun Mar 07, 2021 3:23 pm
According to the data sheet, the MCP3008 is capable of double ended input.
However I do not know what commands to send to enable this function.
For example differential channel 0 uses CH0 and CH1 as its inputs.
BillPretty
Re: MCP3008 Double Ended Input ??
by adafruit2 on Fri Mar 12, 2021 12:43 pm
what programming/IDE ar eyou using, arduino?
adafruit2
Site Admin
by franklin97355 on Fri Mar 12, 2021 1:22 pm
You can look at the GitHub post to see that we support differential input if that helps. https://github.com/adafruit/Adafruit_MCP3008/blob/master/Adafruit_MCP3008.h#L40
franklin97355
by BillPretty on Fri Mar 12, 2021 3:04 pm
adafruit2 wrote:what programming/IDE are you using, arduino?
I am using a Raspberry Pi 3 with the Geany IDE (Python).
I have found several project ideas, but they are single ended.
BillPretty
by adafruit2 on Sun Mar 14, 2021 12:42 pm
the circuitpython library has differential support
https://github.com/adafruit/Adafruit_Ci ... pletest.py
adafruit2
Site Admin
by BillPretty on Sun Mar 14, 2021 3:38 pm
Thank you
BillPretty
