Python Plotting problem
by BillPretty on Sun Mar 14, 2021 3:46 pm
I am having problems with the following code, running on a Raspberry pi 3
I can plot the graphs individually so I know the hardware is working.
When I run this code I see four graphs but nothing is plotted.
Code:
from gpiozero import CPUTemperature
from time import sleep, strftime, time
import matplotlib.pyplot as plt
import os
import busio
import digitalio
import board
import adafruit_mcp3xxx.mcp3008 as MCP
from adafruit_mcp3xxx.analog_in import AnalogIn
# create the spi bus
spi = busio.SPI(clock=board.SCK, MISO=board.MISO, MOSI=board.MOSI)
# create the cs (chip select)
cs = digitalio.DigitalInOut(board.D22)
# create the mcp object
mcp = MCP.MCP3008(spi, cs)
# create cpu object
cpu = CPUTemperature()
# Initialise the subplot function using number of rows and columns
figure, axis = plt.subplots(2, 2)
# create an analog input channel on pin 0
chan0 = AnalogIn(mcp, MCP.P0)
while True:
    x= time()
    # plot temperature
    temp = cpu.temperature
    axis[0,0].plot(x,temp)
    plt.draw()
    print ('Core Temperature:' + str(temp))
    plt.pause(1)
    # plot +5V
    adc=chan0.voltage
    axis[0,1].plot(x,chan0.voltage)
    plt.draw()
    print('ADC Voltage: ' + str(chan0.voltage) + 'V')
    plt.pause(1)
BillPretty
Re: Python Plotting problem
by BillPretty on Wed Mar 17, 2021 2:57 pm
Well folks I got the software working.
The hardware uses a two 4.99K 1% resistors as a voltage divider, to measure the 5 volt input.
The user can easily use the same type of divider to measure the 3.3 volt rail.
The working code is shown below:
Code:
#sudo apt-get install python3-matplotlib
#sudo apt-get install python3-gi-cairo
#sudo pip3 install adafruit-circuitpython-mcp3xxx
#sudo pip3 install adafruit-blinka
import os
import busio
import digitalio
import board
# create cpu object
figure, axs = plt.subplots(2)
plt.ion()
x1 = []
x2 = []
y1 = []
y2 = []
while True:
# plot temperature
y1.append(temp)
x1.append(time())
axs[0].set_title("Core Temperature")
axs[0].plot(x1,y1)
# plot +5V
# Get the ADC measurement X2 for voltage divider
adc=chan0.voltage * 2
y2.append(adc)
x2.append(time())
axs[1].set_title("5V Rail")
axs[1].plot(x2,y2)
print('ADC Voltage: ' + str(adc) + 'V')
plt.pause(1)
BillPretty
