Battery Charge Time
Battery Charge Time
by greyguy1 on Tue Mar 16, 2021 1:24 pm
Hello, I currently have the charger seen in the photo (powerboost 500) hooked up to a 3700mah battery. It has been charging for 6 hours and the red light saying it still cannot provide a 3.2v output is still on. Is that normal? Also, the green and yellow light on the right are illuminated along with blue light on bottom left. Thank you!
greyguy1
Re: Battery Charge Time
by adafruit_support_mike on Tue Mar 16, 2021 11:04 pm
If the yellow and green LEDs are both lit, that means the LiPo charger on the PowerBoost has detected a fault with the battery.
by greyguy1 on Wed Mar 17, 2021 9:10 am
My apologies, I thought I attached the photo.
greyguy1
by franklin97355 on Wed Mar 17, 2021 12:18 pm
It looks like the battery is in reverse polarity. Can you test for that?
franklin97355
by greyguy1 on Wed Mar 17, 2021 3:09 pm
That was the culprit! Thank you! Charges perfect now.
greyguy1
