programming SW-18010p with GEMMA by Arduino
by Hajir on Wed Mar 17, 2021 12:18 pm
i have tried to program SW-18010p with Gemma M0 but i have not get result.
the code is when i shake SW-18010p, the led D1 should turn on, otherwise it will turn off.
but the result is the led is turn on, it does not respond to the movement of SW-18010p.
i need your help as soon as possible.
const int LED = 1; //Buzzer connected to pin 8 of Arduino uno / mega
int sensor;           //Variable to store analog value (0-1023)
void setup()
  pinMode(LED, OUTPUT);
void loop()
  sensor = analogRead(1);
  if (sensor<1022){
    digitalWrite(LED, HIGH);
  else{
     digitalWrite(LED, LOW);
  delay(100); //Small delay
i need help as soon as possible.
kind regards
hajer
Hajir
Re: programming SW-18010p with GEMMA by Arduino
by dastels on Wed Mar 17, 2021 12:51 pm
To start with, you're reading the sensor and writing the LED on the same pin.
dastels
