8X8 matrix display
8X8 matrix display
by jnunes on Sun May 09, 2021 6:42 pm
Hi
I am trying to get numbers to display on the 8x8 matrix. When the program starts, it does display 1 , but it then is blank after that. Please look at my code. Thank you
  This is a library for our I2C LED Backpacks
  Designed specifically to work with the Adafruit LED Matrix backpacks
  ----> http://www.adafruit.com/products/872
  ----> http://www.adafruit.com/products/871
  ----> http://www.adafruit.com/products/870
  These displays use I2C to communicate, 2 pins are required to
  interface. There are multiple selectable I2C addresses. For backpacks
  with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
  with 3 Address Select pins: 0x70 thru 0x77
  products from Adafruit!
  BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <Adafruit_GFX.h>
#include "Adafruit_LEDBackpack.h"
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
  Serial.begin(9600);
  Serial.println("8x8 LED Matrix Test");
  int i=0;
  matrix.begin(0x70);// pass in the address
  matrix.clear();
  matrix.print('1');
  matrix.writeDisplay();
  delay(500);
  matrix.clear();
  matrix.print('2');
  delay(500);
  matrix.clear();
  matrix.print('3');
  delay(500);
  matrix.clear();
  matrix.print('4');
  delay(500);
Reason: Added code tags
jnunes
Re: 8X8 matrix display
by franklin97355 on Sun May 09, 2021 7:55 pm
Which matrix did you get and how do you have it connected?
franklin97355
by jnunes on Mon May 10, 2021 7:43 am
I have this one
https://www.adafruit.com/product/870
I have it wired to an Arduino Uno board and I am using the SCL and SDA connectors on the Arduino Uno board. The example code works perfect. But I can not get it ti display numbers. This is for a score board project
jnunes
