Solar panels and item water pump 4546
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
Kaytee
Post by Kaytee »
We 2 have solar panels .5W, 5 V and 100mA. Will they power your small water pump - item 4546.
sj_remington
Re: Solar panels and item water pump 4546
Post by sj_remington »
Possibly, but perhaps only under conditions of full noon sun, with the panels wired in parallel and directly facing the sun.
The startup current of brushed DC motors is typically 5 to 10 times higher than the normal running current. As a general rule, choose a power supply capable of supplying significantly more current than the maximum you ever expect to draw.
sj_remington is correct about the startup current. This is especially true for a submersible pump which will be starting under load.
A large capacitor wired in parallel with the pump should help a bit with the startup current demands. https://www.adafruit.com/product/1589
Kaytee
Post by Kaytee »
Thank you ! Your comments were very helpful!
Return to “For Educators”
