Solar panels and item water pump 4546
- Kaytee
We 2 have solar panels .5W, 5 V and 100mA. Will they power your small water pump - item 4546.
- sj_remington
Re: Solar panels and item water pump 4546
Possibly, but perhaps only under conditions of full noon sun, with the panels wired in parallel and directly facing the sun.
The startup current of brushed DC motors is typically 5 to 10 times higher than the normal running current. As a general rule, choose a power supply capable of supplying significantly more current than the maximum you ever expect to draw.
sj_remington is correct about the startup current. This is especially true for a submersible pump which will be starting under load.
A large capacitor wired in parallel with the pump should help a bit with the startup current demands. https://www.adafruit.com/product/1589
- Kaytee
Thank you ! Your comments were very helpful!
