I am trying to access the accelerometer on the PyGamer with CircuitPython. The PyGamer pinout page doesn't specifically state how it is connected (i2c, spi). I tried accessing it with CircuitPython via I2C and I get a ValueError - No I2C device at address: 18. The code I am using is below. First, is the sensor wired for i2c or spi, if i2c, what would cause this error?
Thanks in advance for any help.
import time
import board
import digitalio
import adafruit_lis3dh
i2c = board.I2C()
int1 = digitalio.DigitalInOut(board.ACCELEROMETER_INTERRUPT)
lis3dh = adafruit_lis3dh.LIS3DH_I2C(i2c, int1=int1)
LIS3DH on PyGamer using CircuitPython
- adafruit_support_carter
Re: LIS3DH on PyGamer using CircuitPython
On the PyGamer, the LIS3DH uses the alternative address of 0x19 instead of the default 0x18. Try:
lis3dh = adafruit_lis3dh.LIS3DH_I2C(i2c, address=0x19, int1=int1)
- kramlichd
Thanks, that appears to work.
