I am quite experienced in python both on pc and main line micro python but this is my first time using Adafruit's port of circuit python. I am also experienced using embedded C on the STM32 line of MCUs.
I updated the boot loader to "update-bootloader-arcade_pybadge-v3.13.0.uf2" then dropped "adafruit-circuitpython-pybadge-en_US-7.0.0.uf2" to install the circuit python firmware. downloaded and unziped the library bundle "adafruit-circuitpython-bundle-7.x-mpy-20211122" and dropped all the libraries on to pybadge in the lib folder (I was surprised that they all fit).
I downloaded and installed the mu-editor then opened and selected circuit python and played around with some simple code as well as the pybadge examples, all worked as expected including the serial terminal.
I now decided to try the bouncing ball example found here "https://learn.adafruit.com/circuitpytho ... cing-balls". I have seen deshipu sprite libiary in action in micro python before.
When I saved the first couple of lines of code it bricked circuit python.
import ugame
import stage
How can I wipe code.py so that I can start again??
