Mini Spy Camera not saving photos onto SD Card
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
pnat1040
Post by pnat1040 »
Hello! My students are working on a project with the Mini Spy Camera with Trigger for Photo or Video (Part No. 3202). The code below compiles and will upload to the Arduino Uno or MEGA that we have tried, and the LED associated with pin 13 on the Arduino blinks every 10 seconds as does the BLUE LED on the camera module (interestingly, not the red LED as listed in the documentation) at the same rate, so it appears to be taking photos, but nothing shows up on the SD card. The card was formatted FAT32 (as suggested in the documentation). We just can't figure out why pictures are not getting saved on the SD card as the documentation indicates it should happen automatically. If you have any insight, please let us know!
The code the students used they got from a sample project given on adafruit below the product (shown below):
int trig = 2;
int led = 13;
  // initialize the digital pins as output.
  pinMode(led, OUTPUT);
  pinMode(trig, OUTPUT);
  digitalWrite(led, HIGH);
  digitalWrite(trig, HIGH);
// Hold HIGH and trigger quick (<250ms) LOW to take a photo. Holding LOW and trigger HIGH starts/stops video recording
  digitalWrite(trig, LOW);
  digitalWrite(led, LOW);
  delay(50);
  //Delay between pictures
  delay(10000);
adafruit_support_mike
Re: Mini Spy Camera not saving photos onto SD Card
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
pnat1040
Post by pnat1040 »
Thanks for the reply! Attached is a photo of how everything is connected to a MEGA2560 R3, but the students had tried similar connections with an Arduino MEGA. Let me know if you want to see anything else. The SD card they have inserted is a mini SD 32 Gb (we have tried two different 32 Gb SD cards with the same result.
mini_spycam_sample_connections (800 x 600).jpg (76.67 KiB) Viewed 1625 times
Everything seems to be in order there, and those camera modules can ber flaky at times.
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
Return to “For Educators”
