Circuit Playground Classics---dying in droves
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
shop4mondon
Re: Circuit Playground Classics---dying in droves
Post by shop4mondon »
/dev/cu.BLTH				/dev/tty.BLTH
/dev/cu.Bluetooth-Incoming-Port		/dev/tty.Bluetooth-Incoming-Port
/dev/cu.usbmodem141101			/dev/tty.usbmodem141101
adafruit2
Post by adafruit2 »
ok cool, next up do you have homebrew installed on the mac, so you can run 'brew install lsusb'?
shop4mondon
No, I do not have "Home Brew"...
...But, I can look for it and install it
adafruit2
Post by adafruit2 »
its really useful! its also the easiest way for us to find the VID/PID that will tell us if the bootloader is launching right!
shop4mondon
OK
I installed Home Brew
I will need coaching on the next steps
adafruit2
Post by adafruit2 »
install with
brew install lsusb
https://formulae.brew.sh/formula/lsusb
shop4mondon
I have it installed
What's next ?
adafruit2
Post by adafruit2 »
ok in bootloader mode and plugged into mac, run `lsusb` in terminal
then do the same in non-bootloader mode
paste BOTH outputs and indicate which is which
shop4mondon
I got an error message in the Terminal telling me "command not found"
adafruit2
Post by adafruit2 »
`brew install lsusb` didnt work then
shop4mondon
I tried to upload the sketch and ran the code in the terminal. I got the output in screenshot1
Then, I tried to upload again...double clicked the reset button and got the code in screenshot2
Screen Shot 1.png (64.27 KiB) Viewed 1524 times
Screen Shot 2.png (15.4 KiB) Viewed 1525 times
adafruit2
Post by adafruit2 »
ok now run lsusb in the windows
shop4mondon
I don't know what you mean when you say run it in the windows
adafruit2
Post by adafruit2 »
the terminal window
type in
lsusb
the program ya just installed
shop4mondon
THANX
Here's what I got
Last login: Tue May 24 14:24:37 on ttys000
The default interactive shell is now zsh.
To update your account to use zsh, please run `chsh -s /bin/zsh`.
For more details, please visit https://support.apple.com/kb/HT208050.
BSH-STF-DCARTE3:~ don.carter$ lsusb
2022-05-24 16:13:43.518 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:13:43.519 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:13:43.520 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
2022-05-24 16:13:43.521 system_profiler[17926:332216] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
Bus 020 Device 001: ID 05ac:100f Apple Inc. USB2.0 Hub
Bus 020 Device 013: ID 046d:c016 Logitech Inc. Optical USB Mouse
Bus 020 Device 002: ID 05ac:1460 Apple Inc. USB-C Digital AV Multiport Adapter  Serial: DLC926700K3G2KQAE
Bus 000 Device 001: ID 05ac:100e Apple Inc. USB3.0 Hub
/usr/local/bin/lsusb: line 89: 16#80
80
80
80
80: syntax error in expression (error token is "80
80
80
80")
Bus 000 Device 000: ID 05ac
05ac
05ac
05ac
05ac:027a
8103
8262
8514
8233 Apple Inc.
Apple Inc.
Apple Inc.
Apple Inc.
Apple Inc. Apple Internal Keyboard / Trackpad  Serial: FM7919708Q7HYMLAC+MDG
000000000000
000000000000
DJH9225FL7EJ3Y51P
0000000000000000
Bus 000 Device 001: ID 1d6b:PTLP Linux Foundation USB 3.0 Bus
Bus 000 Device 001: ID 1d6b:CITR Linux Foundation USB 3.1 Bus
Bus 000 Device 000: ID 05ac:027a Apple Inc. Apple T2 Bus
Post Reply
Return to “For Educators”
