📣📪 🚚 Adafruit will not be shipping USPS orders Monday January 20, 2020 🗓. Expedited USPS orders placed after 11am ET 🕚 Friday January 17 will go out Tuesday January 21 📣📪🚚
Best accelerometer for measuring Soccer impacts?
Re: Best accelerometer for measuring Soccer impacts?
by adafruit_support_bill on Mon Oct 31, 2016 5:49 am
what would I have to change if I wanted to feed the data directly to my laptop?
Replace calls to "datafile.println" with calls to "Serial.println". That will stream the data back to your computer via the USB/Serial connection.
by jctj on Mon Oct 31, 2016 9:44 am
Thank you!
jctj
by ercdvs on Tue Dec 20, 2016 3:40 pm
Hello all, this project is a good basis for what I want to do, only with motion vs impact.
If i want to use the same hardware, will this support the use of an exernal display counter, such as the https://www.adafruit.com/products/3130
keeping small and compact is best, and i am hoping to normalize the movement in most one axis and provide a counter for that complete motion ie, up and down) plus ome button for resetting the values to zero, etc.
I originally would use a Rpi3 + wiimote to do this, but this seems like a much more compact idea
ercdvs
by adafruit_support_bill on Tue Dec 20, 2016 4:32 pm
The #3130 Alphanumeric Feather Wing is best paired with one of our Feather processors. Any of which are capable of interfacing with the accelerometers as well:
https://www.adafruit.com/categories/830
The easiest one to get started with is probably the Feather 32U4 basic: https://www.adafruit.com/products/2771
by adafruit_support_bill on Sat Jul 20, 2019 7:15 am
See table 4 on page 9 of the datasheet. The board is shipped with 0.1 uF caps - giving it an out-of-the-box bandwidth of 50 Hz.
It should be possible to achieve 1KHz by replacing the caps.
https://www.analog.com/media/en/technic ... DXL377.pdf
https://learn.adafruit.com/assets/36181
