Issue with BBB + 4.3" Adafruit DIsplay (not a cape)
by BeagleBoner on Tue May 16, 2017 4:54 am
I'm running Debian Jessie 8.7 with 4.4.54-ti Kernel and got some problems to get my 4.3" Adafruit Display running via the parallel port (16 Bit). I've connected the display with the 40pin TFT friend to the ports of my BBB. I've connected the open RGB inputs (LSB) to GND for now. The display shows the linux desktop, but just uses the left side of the display, so its distorted. However touch works fine on the whole screen.
I use the following overlay, input timing values should be ok I think?
https://github.com/beagleboard/bb.org-o ... 1-00A0.dts
Any ideas or hints what could be wrong?
Cheers, Max
BeagleBoner
Re: Issue with BBB + 4.3" Adafruit DIsplay (not a cape)
by BeagleBoner on Tue May 16, 2017 5:26 am
Hey,
a little update:
I just tested with a non desktop version of Debian. It uses the whole screen for the command line! So it might be an Issue with the X11 settings?
BeagleBoner
by drewfustini on Tue May 16, 2017 1:21 pm
Could please post the contents of /etc/X11/xorg.conf ?
drewfustini
by drewfustini on Tue May 16, 2017 6:09 pm
drewfustini
by BeagleBoner on Wed May 17, 2017 2:18 am
Hey drew,
yes, this is the display.
Here is the content of /etc/X11/xorg.conf .
Section "Monitor"
        Identifier      "Builtin Default Monitor"
EndSection
Section "Device"
        Identifier      "Builtin Default fbdev Device 0"
        Driver          "fbdev"
#HWcursor_false        Option          "HWcursor"          "false"
EndSection
Section "Screen"
        Identifier      "Builtin Default fbdev Screen 0"
        Device          "Builtin Default fbdev Device 0"
        Monitor         "Builtin Default Monitor"
        DefaultDepth    16
EndSection
Section "ServerLayout"
        Identifier      "Builtin Default Layout"
        Screen          "Builtin Default fbdev Screen 0"
EndSection
I will upload a picture of the running display later this day.
BeagleBoner
by drewfustini on Tue May 23, 2017 3:16 am
I now have the display and adapter that you have and will attempt to replicate the issue.
drewfustini
by BeagleBoner on Wed May 24, 2017 3:22 am
thanks for your efforts drew! Never expected you to actually pick up the hardware and try to rebuild my settings. Wow!
But it looks like I got it running now and you can keep your breadboard in the drawer. ;)
It is a problem with X11 settings. I'm not really sure why it is running now and it seems that xorg settings are still a bit confusing to me. I set default screen depth to 24 bit now but it is acutaly running with 16 bit. In display subsection I set the depth to 16 bit with weight 5/6/5.
"fbset -i" says
mode "480x272"
    geometry 480 272 480 272 32
    timings 0 0 0 0 0 0 0
    accel true
    rgba 8/16,8/8,8/0,0/0
endmode
Frame buffer device information:
    Name        :
    Address     : 0x9c880000
    Type        : PACKED PIXELS
    Visual      : TRUECOLOR
    XPanStep    : 1
    YPanStep    : 1
    YWrapStep   : 0
    LineLength  : 1920
    Accelerator : No
I dont understand why it says 0 timings and 24bit rgba settings when it is just connected with 16bit and shows the desktop fine now.
I will post my updated xorg.conf and logfiles later.
Max
BeagleBoner
by drewfustini on Sat May 27, 2017 11:03 am
I asked Robert Nelson who creates the Debian images.
He advised to delete DefaultDepth option from /etc/X11/xorg.conf.
He also noted this blue-and-red-wiring = "straight"; property in:
https://github.com/beagleboard/bb.org-o ... A0.dts#L95
It looks like some displays have BGR instead of RGB:
/* If you want to get 24 bit RGB and 16 BGR mode instead of
* current 16 bit RGB and 24 BGR modes, set the propety
* below to "crossed" and uncomment the video-ports -property
* in tda19988 node.
drewfustini
cron
