Adafruit_BBIO.GPIO unable to setup pins
by nturner on Mon Sep 11, 2017 7:49 pm
I'm using the Adafruit_BBIO.GPIO python library to control the pins on my BeagleBone Black. Unfortunately whenever I try to use the setup command I get the following message:
ValueError: Set gpio value failed, missing file or invalid permissions.
I'm logged in as root, so I should have all the permissions I need, and I have no idea what file would be missing. A snippet of my code is below.
import Adafruit_BBIO.GPIO as GPIO
V1 = 'P8_7'
GPIO.cleanup()
GPIO.setup(V1, GPIO.OUT)
nturner
Re: Adafruit_BBIO.GPIO unable to setup pins
by drewfustini on Tue Sep 12, 2017 2:21 am
I believe this a regression caused by this commit:
commit 35718a959b5b73c0774fb3e7d53fd412f1d92ec1
Author: Mark A. Yoder <Mark.A.Yoder@Rose-Hulman.edu>
Date: Fri Jul 28 16:53:39 2017 -0400
Added red and green LEDs
I am investigating further and will update.
drewfustini
by drewfustini on Tue Sep 12, 2017 3:15 am
Please paste the output of:
sudo /opt/scripts/tools/version.sh
drewfustini
by drewfustini on Tue Sep 12, 2017 3:18 am
It seems that this is not a problem with release 1.0.4:
Release 1.0.4
Please install rlease 1.0.4 and re-test:
https://github.com/adafruit/adafruit-beaglebone-io-python/archive/1.0.4.zip
I believe the problem was introduced in the most recent release (1.0.5). It might be a workaround to use 1.0.4 until this issue is resolved.
drewfustini
by nturner on Tue Sep 12, 2017 2:08 pm
drewfustini wrote:Please paste the output of:
sudo: /opt/scripts/tools/version.sh: command not found
I am running Debian, if that makes any difference.
I'll try running version 1.04 like you suggested and let you know how it goes for me.
nturner
by CeesWesseling on Fri Sep 22, 2017 5:46 am
We are experiencing the same problem on BB black 4.4.54-ti-r93 with 1.05. Reverting back to 1.03 worked for us. Will try 1.04 as well.
BTW Is there like a version string in the package? looking at the source I only see VERSION id's of the modules like GPIO.
Adding Adafruit_BBIO.VERSION that has the value as version in the setup.py, e.g the package release number would come in handy.
Thanks.
CeesWesseling
by CeesWesseling on Fri Sep 22, 2017 6:50 am
1.04 also yielded:
ValueError: Set gpio mode failed, missing file or invalid permissions
on a GPIO.setup call.
So we are sticking to 1.0.3 for the moment.
All under python3.4 BTW, had to tweak Encoder.py for that in 1.0.4 as it used v2 print style
CeesWesseling
by drewfustini on Fri Sep 29, 2017 9:37 pm
Thanks for following up. Sorry for the delay. I have been traveling more than normal this month.
Yes, sorry about the python3 syntax error in my Encoder.py. I have fixed that in newer version (which you can't use due to the regression that I merged).
I'm going to focus on fixing that regression introduced by the BeagleBone Blue support and get a new release published. Thanks for your patience.
drewfustini
