UART 2 Issue in Pocket Beagle Bone
by Rohi123 on Wed Dec 06, 2017 5:32 am
Hello All,
I am able to transmit data in UART4 (P2_5 , P2_7)
Now i am trying to transmit data in UART 2 (P1.8, P1.10) in Pocket beagle Bone. I can not see anything coming out .
Here is the steps i followed.
Version :
debian@beaglebone:~$ cat /etc/debian_version
9.1
Enabled UART2 in uEnv.txt
debian@beaglebone:~$ cd /boot
debian@beaglebone:/boot$ sudo nano uEnv.txt
cape_enable=bone_capemgr.enable_partno=BB-UART1,BB-UART4,BB-UART5,BB-UART2
cape_disable=bone_capemgr.disable_partno=
debian@beaglebone:~$ ls -al /dev/ttyS*
crw--w---- 1 root tty 4, 64 Sep 21 21:01 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 Sep 21 21:01 /dev/ttyS1
crw-rw---- 1 root dialout 4, 66 Sep 21 21:01 /dev/ttyS2
crw-rw---- 1 root dialout 4, 67 Sep 21 21:01 /dev/ttyS3
crw-rw---- 1 root dialout 4, 68 Sep 21 21:01 /dev/ttyS4
crw-rw---- 1 root dialout 4, 69 Sep 21 21:01 /dev/ttyS5
Here is the code,
Code :
#include <stdio.h>
#include <string.h>
#include <fcntl.h>
#include <termios.h>
#include <unistd.h>
void main (void)
int file, i;
unsigned char receive[100]; // declare a buffer for receiving data
char buf[20];
size_t nbytes;
ssize_t bytes_written;
printf("UART: Transmission Started.\n");
if ((file = open("/dev/ttyS2", O_RDWR))<0)
printf("UART: Failed to open the file.\n");
return;
struct termios options; // the termios structure is vital
tcgetattr(file, &options); // sets the parameters associated with file
// Set up the communications options:
// 9600 baud, 8-bit, enable receiver, no modem control lines
options.c_cflag = B9600 | CS8 | CREAD | CLOCAL;
options.c_iflag = IGNPAR | ICRNL; // ignore partity errors, CR -> newline
tcflush(file, TCIFLUSH); // discard file information not transmitted
tcsetattr(file, TCSANOW, &options); // changes occur immmediately
strcpy(buf, "This is a test\n");
nbytes = strlen(buf);
while (1)
bytes_written = write(file, buf, nbytes);
sleep(10);
close(file);
I hope someone can help me .
Rohi123
Re: UART 2 Issue in Pocket Beagle Bone
by drewfustini on Sun Dec 10, 2017 2:57 pm
Please check the pin mode for those pins with config-pin utility.
Also, please try the latest Debian 9 ("Stretch") image if possible:
https://elinux.org/Beagleboard:BeagleBo ... tBeagle.29
drewfustini
