BB GPIO unable to unexport gpio
by smbrandonjr on Thu Oct 11, 2018 12:48 am
I want to use gpio0_30 for something in an app I have written. I am unable to unexport the gpio, but can export/unexport others...
I am using a Beaglebone Black, running:
dogtag:[BeagleBoard.org Debian Image 2017-03-19]
bootloader:[/dev/mmcblk0]:[U-Boot 2017.03-00002-gd12b1519b4]
bootloader:[/dev/mmcblk1]:[U-Boot 2018.03-00002-gac9cce7c6a]
kernel:[4.4.54-ti-r93]
nodejs:[v4.9.1]
smbrandonjr
Re: BB GPIO unable to unexport gpio
by drewfustini on Fri Oct 12, 2018 6:34 am
This version is u-boot bootloader on the eMMC is too old.
Please run this command on your BeagleBone to disable the old version of the u-boot bootloader on the eMMC:
sudo dd if=/dev/zero of=/dev/mmcblk1 bs=1M count=10
This will cause the newer u-boot bootloader on the SD card to be used.
drewfustini
by smbrandonjr on Fri Oct 26, 2018 9:27 pm
Thank you for this step. I am just now able to get around performing it and it got me where I needed to be. Thank you.
I am new to beaglebone and am curious if I will be able to use gpio0_2, gpio0_3, gpio0_4, and gpio0_5 or will those always be reserved for eMMC?
smbrandonjr
by drewfustini on Sun Oct 28, 2018 9:55 pm
if you boot from MicroSD, then you can reuse the eMMC pins.
Here is how to to disable eMMC in the u-boot bootloader:
https://elinux.org/Beagleboard:BeagleBo ... rd_devices
drewfustini
by smbrandonjr on Thu Nov 08, 2018 2:08 pm
how can i release these pins so that i may control them?
smbrandonjr
by drewfustini on Thu Nov 08, 2018 2:51 pm
Please paste the content of /boot/uEnv.txt
I should be able to advise which lines that you should change
drewfustini
by smbrandonjr on Thu Nov 08, 2018 3:01 pm
smbrandonjr
by smbrandonjr on Fri Nov 09, 2018 3:52 pm
I'd really like to free up as many of the GPIO as possible...I need to be able to use the ethernet adapter and write my OS to the eMMC...other than that, I would like to be able to use it as my own defined input or output if it will be allowed.
Which of these gpio remain available and how do I free them up?
smbrandonjr
by drewfustini on Tue Nov 13, 2018 11:37 pm
I think you have disabled as many of the peripherals as you can, per your uEnv.txt screenshot.
Which pins are you trying to use?
drewfustini
by smbrandonjr on Wed Nov 14, 2018 10:31 am
Drew,
Thanks for getting back to me. Until I stumbled across your Twitter, I didn't realize your association to OSHPark. Ironically, the hobby project I'm working on involves a PCB I had OSHPark create for me (very happy with the results). Unfortunately I made some oversights regarding which GPIOs I would have available and need to create a new version of my PCB.
I need to be able to use at least 45 GPIO for my project. I am not married to any specific GPIO except Serial4_RX and Serial4_TX.
Onboard platforms I want to utilize on by BB Black are the eMMC, Ethernet, the Type A USB, and the Mini B USB (my lack of understanding of the BB platform and embedded hardware in general prevents me from understanding whether modifying/utilizing the accessible GPIO with my application would impact any of those onboard devices...well I realize the eMMC platform based on our previous discussions but am unsure on the others)
smbrandonjr
by drewfustini on Tue Nov 20, 2018 3:30 am
smbrandonjr wrote:Drew,
Hello - I am not certain if it is possible to have 45 GPIOs and eMMC.
I would be a question of the cross section between:
eMMC and HDMI
and
Digital I/O
I would recommend posting on the BeagleBoard.org community mailing list as it has a much wider audience including Jason Kridner (co-creator of the BeagleBone) and Robert Nelson (who creates the Debian images and kernel builds):
http://bbb.io/discuss
drewfustini
