Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
BBI0 PWM Bug
BBI0 PWM Bug
by alarm on Sun Aug 07, 2016 11:31 am
I'm in the Debian GNU / Linux 7.11 (wheezy) kernel 3.8.13-bone80.
I made a python3 script to generate 6 frequencies with a time interval of 15 seconds:
78,156,312,625,1250,2500 Hz
This works fine except that the 4th frequency (625 Hz here) does not pass, I stay on the Previous frequency for 15 seconds.
If I replace 625Hz with another I have the same bug.
Here is the script:
import time
Adafruit_BBIO import from PWM
freq400k_pin = "P9_14" fixed #frequence for therapeutic pulse
freq_var_pin = "P8_19" #frequence modulating
freq_var_liste = (78,156,312,625,1250,2500) # Tuple of 6 frequencies
CYCLE_TIME = 15 #duree cycle: 15 seconds
PWM.start (freq400k_pin, 45, 400000)
PWM.start (freq_var_pin, 0, 50)
try:
while True:
for freq in freq_var_liste:
print ( "= frequency" freq "Hz")
PWM.start (freq_var_pin, 50, freq)
time.sleep (CYCLE_TIME)
except KeyboardInterrupt:
PWM.cleanup ()
Someone there you an idea of ​​the bug?
Thank you
alarm
Re: BBI0 PWM Bug
by drewfustini on Mon Aug 08, 2016 1:31 pm
I've not seen this issue before. Are you able to individually set the frequency to 625 Hz, with out the loop?
drewfustini
Re: BBI0 PWM Bug
by alarm on Mon Aug 08, 2016 2:45 pm
yes, I can manage the frequency of 625Hz.
If I swap the frequency of 78Hz with the 625Hz frequency, I have the same problem with the frequency of 78Hz.
alarm
Re: BBI0 PWM Bug
by drewfustini on Tue Aug 09, 2016 12:10 am
There is a new pull request by MatthewWest on Github that add support for Linux 4.1 kernel to Adafruit_BBIO:
https://github.com/adafruit/adafruit-be ... n/pull/108
I've yet to test this with different versions of Debian images, but you may want to try this with the latest Debian Jessie image:
http://beagleboard.org/latest-images
Here is the branch to try:
https://github.com/MatthewWest/adafruit ... ts/develop
drewfustini
Re: BBI0 PWM Bug
by alarm on Tue Aug 09, 2016 10:17 am
So I installed the latest version of debian jessie to the BBB:
Distributor ID: Debian
Description: Debian GNU / Linux 8.4 (jessie)
Release: 8.4
Codename: jessie
I cloned the branch:
I did the installation for python3.
When I run my script, I receive the following error message:
File "cycle_pwm_1.py", line 8, in <module>
PWM.start (freq_var_pin, 0.50)
RuntimeError: Problem with a sysfs file
What to do ?
alarm
Re: BBI0 PWM Bug
by alarm on Tue Aug 09, 2016 11:50 am
I solved my problem by making the following operation:
I removed the # in the following line in the file /boot/uEnv.txt
#Bone_capemgr.enable_partno=
then reboot
I handed the #
then reboot again
I have no error message.
I can generate the 6 frequencies.
Do you think the cause is related to the command line?
Thank you for your help
alarm
Re: BBI0 PWM Bug
by drewfustini on Fri Aug 12, 2016 7:30 pm
Please try out Matthew West's develop branch. He has several more fixes in it now:
I tested it out ok with all the BeagleBone SD card images that I have.
The pull request should be merged into the Adafruit repo soon.
drewfustini
