Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more. Accepting essential orders - here's how.
automating "config-pin P9.30 spi"
by rifo on Thu Aug 25, 2016 1:44 pm
I am trying to automate configuring spi pins. I need to issue below commands
config-pin P9.28 spi
config-pin P9.29 spi
config-pin P9.31 spi
When I do it manually, everything works fine but when I try to automate it. This doesn't work.
I have tried adding it to
* /etc/rc.local
* systemd
* monit
for some reason, this doesn't work. Can you please tell me where I should place these commands?
thanks
rifo
rifo
Re: automating "config-pin P9.30 spi"
by rifo on Fri Aug 26, 2016 11:37 am
I have done some more trials. It seems that I need to insert a delay of 7 seconds in the application itself before issuing the "config-pin P9.30 spi" command from the application itself via "system" command
without the delay, P9.30 pin stays in default mode.
rifo
by drewfustini on Fri Aug 26, 2016 11:43 pm
Thanks for the insight.
For startup, creating a new systemd unit file should work:
systemd: Writing and Enabling a Service
drewfustini
by rifo on Sat Aug 27, 2016 3:05 am
Hello Drew,
I didn't know that systemd can generate a delay in startup before launching the application. This would be much better for me.
Thanks for tip. I'll look that up.
rifo
